Custom Text Contol ActiveX
Started by Michael Meeks, March 12, 2005, 01:50:41 PM
Michael Meeks
Hi,
I have a custom text control - everything shows up fine - compiles - displays etc.
In VB - you would use:   textControl1.Load "Filename", 30, %Type
In FireFly - how would I do the same thing ?
Thanks in advance.
Mike
Jose Roca
DIM v1 AS VARIANT
DIM v2 AS VARIANT
DIM v3 AS VARIANT
v1 = "Filename"
v2 = 30
v3 = %Type
OBJECT CALL DISPATCH_FORM1_textControl1.Load(v1, v2, v3)
Michael Meeks
Thank You Jose...
Your the Master!  Works like a charm!
Mike
Michael Meeks
Hi,
If anyone is interested...
http://www.sewardak.net/demo/word2pdf.png
Attempted - using PB Only - but FireFly - make's it so much easier!
FYI -  :D  This Control is very spendy!  (professional version only)
$ 716.50 at componentsource.com (where we purchased it)
$ 949.00 at textcontrol.com
The TX-Control: http://www.textcontrol.com/products/activex/
DOC, RTF, TXT, HTML, CSS, XML, PDF.
Build applications that handle all these formats and many more using TX Text Control ActiveX.
Native PDF support (no driver or 3rd party software)
Publish directly to the web (Save as HTML)
One application for most word processing formats
Image export (JPEG, PNG, BMP and WMF)
Export images to a user defined format.
Many more features.
Regards
Mike
