New Update v 1.1 fixed Timer problems
Started by John Dunbar, April 08, 2005, 04:02:39 PM
John Dunbar
I had v 1.08 and couldn't get Custom function of the timer control to fire.  I then upgraded to 1.1 and still had same problem.  But after I deleted the old Timer control from my form AND deleted the old generated 1.08 code for the CUSTOM handler for the timer, everything worked.  I noticed that the calling parameters were significantly different.
I'm happy this is working now.  Should I delete and then regenerate my event functions whenever I upgrade?  It's not the end of the world as I usually keep all my code outside of these functions.
John Dunbar
