Display Only TextBox
Started by Marty Francom, June 16, 2005, 01:33:23 PM
Marty Francom
Is it possible to make a TextBox  display only?  I want to display some data in a TextBox but I don't want the user to be able to edit that data. (this data is programmically generated)
dacarle
Jean-Pierre LEROY
Hi Marty,
In the Properties of the TextBox -> WindowsStyles -> Style, you just have to check "ES_READONLY".
That's all.
Jean-Pierre.
Marty Francom
thanks,  Jean
  I thought there ought to be an easy way to do this. Just couldn't find where to make that setting change.
