CheckBox & OptionButton
Started by Marty Francom, June 19, 2005, 12:56:18 AM
Marty Francom
When I use a CheckBox on a form and set its property to "checked" then later deside to change it back to "un-checked"   It will NOT stay set to the "un-checked" state.   This also occurs with the OptionButton.
I can fix the problem by setting the CheckBox or OptionBottons state at program start up.
I though you would want to know.
Thanks Marty, I will check into that on Monday and make any necessary corrections.
It has been doing that for a while in the IDE. It forgets settings, but shows correct in compile.
