Compiler results Problem
Started by Marty Francom, July 14, 2005, 07:46:01 PM
Marty Francom
Con't know if the Compiler results message box is being created by PB or by Firefly.  But what the problem is that their are more files being processed and listed than will fit on my computer monitor.  The message box has no scroll bar so it is impossible to view all the info in this message box.
 If this is a FireFly Message Box, could it be redesigned so that it has scroll bars?  Also,  if the Copy/Paste  ClipBoard would work.  then it would be possible to copy error messages and paste them on an email.
It is PB 8 that you're using, right? The new compiler generates the listing in the listbox. It is a PB message, not FireFly. Personally, I am not fond of the listing of files. I would prefer the old way where it only listed the main file.
