tabcontrol
Started by Anonymous, August 15, 2005, 06:52:03 AM
Anonymous
it seems to be a bug with the tabcontrol.
If i create a tabcontrol with TCS_Singleline - it works fine.
If i use TCS_Multiline, the form's in then second row of the tabcontrol
are not in the right position.
Please look at the sample here:
http://members.aon.at/ar_s/ForumBilder/TabControl.zip
The problem is not so important, but maybe for the next update.
Thanks!
Fürstauer Rudolf
Yes, you're right. I will fix that for the next update. Thanks!
