Author Topic: working example of FF_OpenFileDialog  (Read 383 times)
Anonymous
  • Guest
« on: September 15, 2005, 05:18:50 AM »
Hi,
can anyone provide me with a working example of FF_OpenFileDialog command.
Thanks
Herbx
Anonymous
  • Guest
« Reply #1 on: September 15, 2005, 06:36:32 AM »
Sorted it out, thanks.
Herbx
  • Guest
« Reply #2 on: September 16, 2005, 05:18:00 AM »
Yeah, he made it pretty straight forward.  Only issues I ever remember having was when I played around with styles.  If you want the new looking Win9x/XP style dialog and you specify any flags you have to also specify the flag for the new look.  Something to do with the flag for subclassing the dialog to center it if I recall where when that flag is on then it shows as the old style by default, and Paul made it so if you don't specify flags it uses common ones, but if you specify it only uses your flags..
