Author Topic: Suggestion for the search function  (Read 220 times)
Marty Francom
  • Guest
« on: September 21, 2005, 06:23:54 PM »
.. It would be very useful if the seach function of the FF editing enviroment would allow the user to search ALL moduals of a project for a particular bit of code.
.. I have a project that has a large number of moduals (inc files) and resently I needed to find a bit of code but could not remember which file it was in.  Finally found it after much hunting and frustration.
.. It would have been very useful if FF seach function had an option to search ALL moduals for the bit of code that a programmer might be searching to find.
..  Would it be possible to add an option to the search function in FF to allow the user to search ALL moduals instead of only the current modual?
...Marty
