Author Topic: Multi-screen glitch?  (Read 449 times)
Peter Presland
  • Guest
« on: September 06, 2008, 10:32:03 AM »
Another little problem which turns out not to be a problem once you know about it:
My development machine runs two screen. If I close FF while the Main window is on the secondary screen, when I restart I am prompted with a message that says the program is configured to display outside the current screen area ..... and a prompt to reposition or not. If I select <No>,  the 'Firefly Workspace - Tools' window has no icons displayed (or sometimes just two or three which bear no apparent relationship to what the project itself contains). If I select <yes> all is OK but I have to drag the window back onto my secondary display to get it how I prefer working. No exhaustive testing here but I have reproduced the behavior several times
A multi-screen glitch of some sort maybe?
Anyway, so far I'm impressed - but then I must also admit to being a rank beginner with PB and visual design/windows programming generally
Peter Presland
