Author Topic: DateTimePicker Control Take 2  (Read 592 times)
Andrew Lindsay
« on: December 19, 2009, 06:09:00 PM »
OK,
A second 'issue' with the DateTimePicker control.
When I use a format on hh:mm:ss, I can not get it to show 24 hour time, instead, when I toggle up and down on the hours sector (i.e. use the up and down arrows to cycle up or down, it just goes to 12, and not 13, 14 15 ... 23, 0 , 1, 2, 3 etc.
How do I get 24 hour time to be displayed?
Regards
Andrew
Re: DateTimePicker Control Take 2
« Reply #1 on: December 19, 2009, 07:24:27 PM »
The format string is all explained at this link: http://msdn.microsoft.com/en-us/library/bb761726(VS.85).aspx
In your WM_CREATE for the form, set the date format to use 24-hour.
Function FORM1_WM_CREATE ( _
    Local hWndControl As Dword
    hWndControl = HWND_FORM1_DATETIMEPICKER1
    DateTime_SetFormat hWndControl, "HH-mm-ss"
...etc...
Andrew Lindsay
« Reply #2 on: December 20, 2009, 07:35:54 AM »
Cheers Paul,
Much apreciated.
Regards
Andrew
