Pages: 1 ... 3 4 [5]
Author Topic: CWindow RC05  (Read 18410 times)
Re: CWindow RC05
« Reply #60 on: May 06, 2016, 09:27:57 PM »
Menu wrapper functions (continued).
' Retrieves the state of the specified menu item.
' - hMenu = A handle to the menu that contains the menu item.
' - uItem = The identifier or position of the menu item to get information about.
'           The meaning of this parameter depends on the value of fByPosition.
' - fByPosition = The meaning of uItem. If this parameter is FALSE, uItem is a menu item
'           identifier. Otherwise, it is a menu item position.
' Return Value: 0 on failure or one or more of the following values:
' - MFS_CHECKED   The item is checked
' - MFS_DEFAULT   The menu item is the default.
' - MFS_DISABLED  The item is disabled.
' - MFS_ENABLED   The item is enabled.
' - MFS_GRAYED    The item is grayed.
' - MFS_HILITE    The item is highlighted
' - MFS_UNCHECKED The item is unchecked.
' - MFS_UNHILITE  The item is not highlighed.
' Note: To get extended error information, use the GetLastError function.
PRIVATE FUNCTION AfxGetMenuItemState (BYVAL hMenu AS HMENU, BYVAL uItem AS DWORD, BYVAL fByPosition AS LONG = FALSE) AS DWORD
   DIM mii AS MENUITEMINFOW
   mii.cbSize = SIZEOF(mii)
   mii.fMask = MIIM_STATE
   IF GetMenuItemInfoW(hMenu, uItem, fByPosition, @mii) = 0 THEN EXIT FUNCTION
   FUNCTION = mii.fState
' Sets the state of the specified menu item.
' - fState = The menu item state. It can be one or more of these values:
' - MFS_CHECKED   Checks the menu item.
' - MFS_DEFAULT   Specifies that the menu item is the default.
' - MFS_DISABLED  Disables the menu item and grays it so that it cannot be selected.
' - MFS_ENABLED   Enables the menu item so that it can be selected. This is the default state.
' - MFS_GRAYED    Disables the menu item and grays it so that it cannot be selected.
' - MFS_HILITE    Highlights the menu item.
' - MFS_UNCHECKED Unchecks the menu item.
' - MFS_UNHILITE  Removes the highlight from the menu item. This is the default state.
' Return Value: If the function succeeds, the return value is nonzero. If the function
'   fails, the return value is zero. To get extended error information, use the
'   GetLastError function.
' Note: The application must call the DrawMenuBar function whenever a menu changes,
' whether or not the menu is in a displayed window.
PRIVATE FUNCTION AfxSetMenuItemState (BYVAL hMenu AS HMENU, BYVAL uItem AS DWORD, BYVAL fState AS DWORD, BYVAL fByPosition AS LONG = FALSE) AS LONG
   mii.fState = fState
   FUNCTION = SetMenuItemInfoW(hMenu, uItem, fByPosition, @mii)
' Enables the specified menu item.
PRIVATE FUNCTION AfxEnableMenuItem (BYVAL hMenu AS HMENU, BYVAL uItem AS DWORD, BYVAL fByPosition AS LONG = FALSE) AS LONG
   mii.fState = MFS_ENABLED
' Disables the specified menu item.
PRIVATE FUNCTION AfxDisableMenuItem (BYVAL hMenu AS HMENU, BYVAL uItem AS DWORD, BYVAL fByPosition AS LONG = FALSE) AS LONG
   mii.fState = MFS_DISABLED
' Grays the specified menu item.
PRIVATE FUNCTION AfxGrayMenuItem (BYVAL hMenu AS HMENU, BYVAL uItem AS DWORD, BYVAL fByPosition AS LONG = FALSE) AS LONG
   mii.fState = MFS_GRAYED
' Highlights the specified menu item.
PRIVATE FUNCTION AfxHiliteMenuItem (BYVAL hMenu AS HMENU, BYVAL uItem AS DWORD, BYVAL fByPosition AS LONG = FALSE) AS LONG
   mii.fState = MFS_HILITE
' Removes the system menu close option and disables the X button.
PRIVATE SUB AfxRemoveCloseMenu (BYVAL hwnd AS HWND)
   ' // Get the system menu handle
   DIM hMenu AS HMENU = GetSystemMenu(hwnd, 0)
   IF hMenu = NULL THEN EXIT SUB
   ' // Get the number of menu items
   DIM cbItems AS LONG = GetMenuItemCount(hMenu)
   ' // Remove the close menu item
   RemoveMenu(hMenu, cbItems - 1, MF_REMOVE OR MF_BYPOSITION)
   ' // Remove the separator line
   RemoveMenu(hMenu, cbItems - 2, MF_REMOVE OR MF_BYPOSITION)
   ' // Redraw the menu (this refreshes the caption bar, dimming the X button)
   DrawMenuBar(hwnd)
' Right justifies a top level menu item. This is usually used to have the Help menu item
' right-justified on the menu bar.
' - hwnd  = [in] A handle to the menu that contains the menu item.
' - uItem = [in] The zero-based position of the menu item to change.
' Return value:
'   If the function succeeds, the return value is nonzero.
'   If the function fails, the return value is zero.
PRIVATE FUNCTION AfxRightJustifyMenuItem (BYVAL hMenu AS HMENU, BYVAL uItem AS DWORD) AS LONG
   DIM mii AS MENUITEMINFOW, buffer AS WSTRING * MAX_PATH + 1
   mii.cbSize = SIZEOF(MENUITEMINFOW)
   mii.dwTypeData = @buffer
   mii.cch = MAX_PATH
   mii.fType = MF_STRING
   mii.fState = MFS_DEFAULT
   mii.fMask = MIIM_ID OR MIIM_DATA OR MIIM_TYPE OR MIIM_SUBMENU
   IF GetMenuItemInfoW(hMenu, uItem, CTRUE, @mii) THEN
      mii.fType = mii.fType OR MF_HELP
      FUNCTION = SetMenuItemInfoW(hMenu, uItem, CTRUE, @mii)
' Changes the text of a menu item to bold.
' Return value:
PRIVATE FUNCTION AfxSetMenuItemBold (BYVAL hMenu AS HMENU, BYVAL uItem AS DWORD) AS LONG
   mii.cch = MAX_PATH
   mii.fMask = MIIM_ID OR MIIM_DATA OR MIIM_TYPE OR MIIM_SUBMENU OR MIIM_STATE
   IF GetMenuItemInfoW(hMenu, uItem, TRUE, @mii) THEN
      mii.fState = mii.fState OR &H1000
' Sets the text of the specified menu item.
' - strText = Text to set.
PRIVATE FUNCTION AfxSetMenuItemText (BYVAL hMenu AS HMENU, BYVAL uItem AS DWORD, BYREF wszText AS WSTRING, BYVAL fByPosition AS LONG = FALSE) AS LONG
   mii.fMask = MIIM_STRING
   mii.dwTypeData = @wszText
' Retrieves the text of the specified menu item.
' - hMenu = Handle to the menu that contains the menu item.
PRIVATE FUNCTION AfxGetMenuItemTextA (BYVAL hMenu AS HMENU, BYVAL uItem AS DWORD, BYVAL fByPosition AS LONG = FALSE) AS STRING
   ' // Fills the MENUITEMINFOA structure
   DIM mii AS MENUITEMINFOA
   mii.dwTypeData = NULL
   ' // Get the needed size of the buffer
   IF GetMenuItemInfoA(hMenu, uItem, fByPosition, @mii) = 0 THEN EXIT FUNCTION
   ' // Make room for the trailing null
   mii.cch += 1
   ' // Allocate the buffer
   DIM buffer AS STRING = SPACE$(mii.cch)
   ' // Get the menu string
   mii.dwTypeData = STRPTR(buffer)
   IF GetMenuItemInfoA(hMenu, uItem, fByPosition, @mii) THEN
      FUNCTION = RTRIM(buffer, CHR(0))
' Remarks: The returned WSTRING pointer must be freed with Delete.
' Usage:
' DIM pwsz AS WSTRING PTR
' pwsz = AfxGetMenuItemTextW(hMenu, uItem, fByPosition)
' MessageBoxW 0, *pwsz, "", MB_OK
' IF pwsz THEN Delete(pwsz)
PRIVATE FUNCTION AfxGetMenuItemTextW (BYVAL hMenu AS HMENU, BYVAL uItem AS DWORD, BYVAL fByPosition AS LONG = FALSE) AS WSTRING PTR
   ' // Fills the MENUITEMINFOW structure
   mii.cch += 1
   DIM pbuffer AS WSTRING PTR = CAllocate(mii.cch * 2, 1)
   mii.dwTypeData = pbuffer
   IF GetMenuItemInfoW(hMenu, uItem, fByPosition, @mii) THEN
      FUNCTION = pBuffer
#ifdef UNICODE
   #define AfxGetMenuItemText AfxGetMenuItemTextW
#else
   #define AfxGetMenuItemText AfxGetMenuItemTextA
#endif
Re: CWindow RC05
« Reply #61 on: May 06, 2016, 10:54:50 PM »
Another one:
' Retrieves information about the font used in menu bars.
' If the function succeeds, the return value is a nonzero value.
' To get extended error information, call GetLastError.
FUNCTION AfxGetMenuFont (BYVAL lfw AS LOGFONTW PTR) AS BOOLEAN
   DIM ncm AS NONCLIENTMETRICSW
   IF VARPTR(lfw) = 0 THEN EXIT FUNCTION
   IF AfxWindowsVersion >= 6 THEN ncm.cbSize = 504 ELSE ncm.cbSize = 500
   DIM r AS LONG = SystemParametersInfoW(SPI_GETNONCLIENTMETRICS, SIZEOF(ncm), @ncm, 0)
   IF r THEN *lfw = ncm.lfMenuFont
   FUNCTION = r
Re: CWindow RC05
« Reply #62 on: May 06, 2016, 11:05:43 PM »
' Retrieves the point size of the font used in menu bars.
' If the function fails, the return value is 0.
FUNCTION AfxGetMenuFontPointSize () AS LONG
   IF SystemParametersInfoW(SPI_GETNONCLIENTMETRICS, SIZEOF(ncm), @ncm, 0) = 0 THEN EXIT FUNCTION
   DIM hDC AS HDC = CreateDCW("DISPLAY", NULL, NULL, NULL)
   IF hDC = NULL THEN EXIT FUNCTION
   DIM cyPixelsPerInch AS LONG = GetDeviceCaps(hDC, LOGPIXELSY)
   DeleteDC hDC
   DIM nPointSize AS LONG = MulDiv(ncm.lfMenuFont.lfHeight, 72, cyPixelsPerInch)
   IF nPointSize < 0 THEN nPointSize = -nPointSize
   FUNCTION = nPointSize
Re: CWindow RC05
« Reply #63 on: May 06, 2016, 11:45:38 PM »
This version of FileExists is much more complete than the FB one, since it is only for Windows.
' Searches a directory for a file or subdirectory with a name that matches a specific name
' (or partial name if wildcards are used).
' Parameter:
' - pwszFileSpec: The directory or path, and the file name, which can include wildcard
'   characters, for example, an asterisk (*) or a question mark (?).
'   This parameter should not be NULL, an invalid string (for example, an empty string or a
'   string that is missing the terminating null character), or end in a trailing backslash (\).
'   If the string ends with a wildcard, period (.), or directory name, the user must have
'   access permissions to the root and all subdirectories on the path.
'   To extend the limit of MAX_PATH wide characters to 32,767 wide characters, prepend
'   "\\?\" to the path.
' Return value:
'   Returns TRUE if the specified file exists or FALSE otherwise.
' Remarks:
'   Prepending the string "\\?\" does not allow access to the root directory.
'   On network shares, you can use a pwszFileSpec in the form of the following:
'   "\\server\service\*". However, you cannot use a pwszFileSpec that points to the share
'   itself; for example, "\\server\service" is not valid.
'   To examine a directory that is not a root directory, use the path to that directory,
'   without a trailing backslash. For example, an argument of "C:\Windows" returns information
'   about the directory "C:\Windows", not about a directory or file in "C:\Windows".
'   To examine the files and directories in "C:\Windows", use an pwszFileSpec of "C:\Windows\*".
'   Be aware that some other thread or process could create or delete a file with this name
'   between the time you query for the result and the time you act on the information.
'   If this is a potential concern for your application, one possible solution is to use
'   the CreateFile function with CREATE_NEW (which fails if the file exists) or OPEN_EXISTING
'   (which fails if the file does not exist).
FUNCTION AfxFileExists (BYVAL pwszFileSpec AS WSTRING PTR) AS BOOLEAN
   DIM fd AS WIN32_FIND_DATAW
   IF pwszFileSpec = NULL THEN EXIT FUNCTION
   DIM hFind AS HANDLE = FindFirstFileW(pwszFileSpec, @fd)
   IF hFind = INVALID_HANDLE_VALUE THEN EXIT FUNCTION
   FindClose hFind
   ' // Make sure that it is not a directory or a temporary file
   IF (fd.dwFileAttributes AND FILE_ATTRIBUTE_DIRECTORY) <> FILE_ATTRIBUTE_DIRECTORY AND _
      (fd.dwFileAttributes AND FILE_ATTRIBUTE_TEMPORARY) <> FILE_ATTRIBUTE_TEMPORARY THEN
      FUNCTION = TRUE
Re: CWindow RC05
« Reply #64 on: May 06, 2016, 11:55:19 PM »
' Parameter:
'   access permissions to the root and all subdirectories on the path. To extend the limit
'   of MAX_PATH wide characters to 32,767 wide characters, prepend "\\?\" to the path.
' Return value:
'   Returns TRUE if the specified folder exists or FALSE otherwise.
' Remarks
'   On network shares, you can use an btrFileName in the form of the following: "\\server\service\*".
'   However, you cannot use an btrFileName that points to the share itself; for example,
'   "\\server\service" is not valid.
'   To examine the files and directories in "C:\Windows", use an btrFileName of "C:\Windows\*".
FUNCTION AfxFolderExists (BYVAL pwszFileSpec AS WSTRING PTR) AS BOOLEAN
   FindClose hFind
   ' // Make sure that it is a directory
   IF (fd.dwFileAttributes AND FILE_ATTRIBUTE_DIRECTORY) = FILE_ATTRIBUTE_DIRECTORY THEN FUNCTION = TRUE
Re: CWindow RC05
« Reply #65 on: May 07, 2016, 12:07:59 AM »
' Calculates the size of a menu bar or a drop-down menu.
' - hwnd = Handle of the window that owns the menu.
' - hmenu = handle of the menu.
' - prcmenu = Pointer to a variable of type RECT where to return the retrieved values.
' Return Value:
' If the function succeeds, the return value is 0.
' If the function fails, the return value is  a system error code.
FUNCTION AfxGetMenuRect (BYVAL hwnd AS HWND, BYVAL hmenu AS HMENU, BYVAL prcmenu AS RECT PTR) AS LONG
   DIM i AS LONG, nRes AS LONG, rc AS RECT
   FOR i = 1 TO GetMenuItemCount(hmenu)
      nRes = GetMenuItemRect(hwnd, hmenu, i, @rc)
      IF nRes = -1 THEN nRes = GetLastError : EXIT FOR
      UnionRect prcmenu, prcmenu, @rc
   FUNCTION = nRes
Changed several functions to return a BOOLEAN.
« Last Edit: May 07, 2016, 12:23:10 AM by Jose Roca »
Re: CWindow RC05
« Reply #66 on: May 07, 2016, 03:27:03 AM »
It is more fun than playing cards with other retirees.
:) By the  level of the things you create, I don't think 99% of retirees will understand the slightest bit of what you are doing!
I mean this in the best possible way, but you have to be a kick-ass retiree.  :)
Re: CWindow RC05
« Reply #67 on: May 07, 2016, 04:32:14 AM »
I have a big advantage. As I have learned English mainly reading Microsoft documentation, I have no problems understanding it, whereas native English speakers apparently have great difficulties to understand "Microsoft English". :)
Recently, a PBer has posted in the PB forum: 'Depsite having read and reread the help on Objects, Classes, Methods and Properties I still cannot figure out why I am getting the compiler error " Method or Property Name Expected" on the line "amc.MediaUsername = WEdstr".'
He has declared amc AS DISPATCH and then is trying to use amc to do direct interface calls. That is, he does not understand the difference between Automation and direct interface calls. For some reason, 99% of PBer's seem unable to understand low-level COM programming.
I'm quite sure that Paul has not any problem understanding the code that I'm writing with FB.
Re: CWindow RC05
« Reply #68 on: May 07, 2016, 05:02:18 AM »
You are correct.
Many people do tend to approach programming like they would approach unpacking a complicated sound system:
"IF all else fails....read instructions!"
...and then we don't understand the instructions.....
But then again if com programming we easy, everyone would have programmed.
I still think the work You, Paul, Gary and the others do are pretty much up there with the best, so thanks for all the efforts, because without the work you all do, I still would have tried to make my first button.
Re: CWindow RC05
« Reply #69 on: May 07, 2016, 06:30:50 PM »
Font functions.
' Font enum
enum
   AFX_FONT_CAPTION = 1    ' // Caption font
   AFX_FONT_SMALLCAPTION   ' // Small caption font
   AFX_FONT_MENU           ' // Font used in menu bars
   AFX_FONT_STATUS         ' // Font used in status bars and tooltips
   AFX_FONT_MESSAGE        ' // Font used in message boxes
   ' // Font settings
   AFX_FONT_HEIGHT         ' // Font height
   AFX_FONT_WEIGHT         ' // Font weight
   AFX_FONT_ITALIC         ' // Font italic
   AFX_FONT_UNDERLINE      ' // Font underline
   AFX_FONT_STRIKEOUT      ' // Font strikeout
   AFX_FONT_CHARSET        ' // Font charset
end enum
' Retrieves information about the fonts used by Windows.
' Parameters:
' - nType = The type of font:
'   AFX_FONT_CAPTION, AFX_FONT_SMALLCAPTION, AFX_FONT_MENU, AFX_FONT_STATUS, AFX_FONT_MESSAGE
' - plfw = Pointer to a LOGFONTW structure that receives the font information.
' Return value: TRUE on succes or FALSE on failure.
FUNCTION AfxGetWindowsFontInfo (BYVAL nType AS LONG, BYVAL plfw AS LOGFONTW PTR) AS BOOLEAN
   IF plfw = NULL THEN EXIT FUNCTION
   SELECT CASE nType
      CASE AFX_FONT_CAPTION      : *plfw = ncm.lfCaptionFont
      CASE AFX_FONT_SMALLCAPTION : *plfw = ncm.lfSmCaptionFont
      CASE AFX_FONT_MENU         : *plfw = ncm.lfMenuFont
      CASE AFX_FONT_STATUS       : *plfw = ncm.lfStatusFont
      CASE AFX_FONT_MESSAGE      : *plfw = ncm.lfMessageFont
      CASE ELSE
         RETURN FALSE
   FUNCTION = TRUE
' Retrieves the point size of the fonts used by Windows.
' Parameters:
' Return value: The point size.
FUNCTION AfxGetWindowsFontPointSize (BYVAL nType AS LONG) AS LONG
   DeleteDC hDC
   SELECT CASE nType
      CASE AFX_FONT_CAPTION      : nPointSize = MulDiv(ncm.lfCaptionFont.lfHeight, 72, cyPixelsPerInch)
      CASE AFX_FONT_SMALLCAPTION : nPointSize = MulDiv(ncm.lfSmCaptionFont.lfHeight, 72, cyPixelsPerInch)
      CASE AFX_FONT_MENU         : nPointSize = MulDiv(ncm.lfMenuFont.lfHeight, 72, cyPixelsPerInch)
      CASE AFX_FONT_STATUS       : nPointSize = MulDiv(ncm.lfStatusFont.lfHeight, 72, cyPixelsPerInch)
      CASE AFX_FONT_MESSAGE      : nPointSize = MulDiv(ncm.lfMessageFont.lfHeight, 72, cyPixelsPerInch)
' Returns the point size of a font given its logical height
PRIVATE FUNCTION AfxGetFontPointSize (BYVAL nHeight AS LONG) AS LONG
   DeleteDC HDC
   DIM nPointSize AS LONG = MulDiv(nHeight, 72, cyPixelsPerInch)
' Returns the logical height of a font given its point size
PRIVATE FUNCTION AfxGetFontHeight (BYVAL nPointSize AS LONG) AS LONG
   DeleteDC HDC
   DIM nHeight AS LONG = -MulDiv(nPointSize, cyPixelsPerInch, 72)
   FUNCTION = nHeight
' Modifies the face name of the font of a window or control.
' Parameters:
' - hwnd = Handle of the window or control.
' - pwszNewFaceName = The new face name of the font
PRIVATE FUNCTION AfxModifyFontFaceName (BYVAL hwnd AS HWND, BYREF wszNewFaceName AS WSTRING) AS BOOLEAN
   DIM lfw AS LOGFONTW
   IF hwnd = NULL OR VARPTR(wszNewFaceName) = NULL THEN EXIT FUNCTION
   ' // Get the handle of the font used by the header
   DIM hCurFont AS HFONT = CAST(HFONT, SendMessageW(hwnd, WM_GETFONT, 0, 0))
   IF hCurFont = 0 THEN EXIT FUNCTION
   ' // Get the LOGFONTW structure
   IF GetObject(hCurFont, SIZEOF(lfw), @lfw) = 0 THEN EXIT FUNCTION
   ' // Change the face name
   lfw.lfFaceName = wszNewFaceName
   ' // Create a new font
   DIM hNewFont AS HFONT = CreateFontIndirectW(@lfw)
   IF hNewFont = 0 THEN EXIT FUNCTION
   ' // Select the new font and delete the old one
   DIM hDC AS HDC = GetDC(hwnd)
   DeleteObject(SelectObject(hDC, CAST(HGDIOBJ, hNewFont)))
   ReleaseDC(hwnd, hDC)
   SendMessageW(hwnd, WM_SETFONT, CAST(WPARAM, hNewFont), CTRUE)
   FUNCTION = TRUE
' Modifies settings of the font used by a window of control.
' Parameters:
' - nSetting : One of the AFX_FONT_xxx constants.
' - nValue: Depends of the nSetting value
'   AFX_FONT_HEIGHT
'      The base is 100. To increase the font a 20% pass 120; to reduce it a 20% pass 80%.
'   AFX_FONT_WEIGHT
'      The weight of the font in the range 0 through 1000. For example, 400 is normal and
'      700 is bold. If this value is zero, a default weight is used.
'      The following values are defined for convenience.
'      FW_DONTCARE (0), FW_THIN (100), FW_EXTRALIGHT (200), FW_ULTRALIGHT (200), FW_LIGHT (300),
'      FW_NORMAL (400), FW_REGULAR (400), FW_MEDIUM (500), FW_SEMIBOLD (600), FW_DEMIBOLD (600),
'      FW_BOLD (700), FW_EXTRABOLD (800), FW_ULTRABOLD (800), FW_HEAVY (900), FW_BLACK (900)
'   AFX_FONT_ITALIC : TRUE or FALSE.
'   AFX_FONT_UNDERLINE : TRUE or FALSE.
'   AFX_FONT_STRIKEOUT : TRUE or FALSE.
'   AFX_FONT_CHARSET
'      The following values are predefined: ANSI_CHARSET, BALTIC_CHARSET, CHINESEBIG5_CHARSET,
'      DEFAULT_CHARSET, EASTEUROPE_CHARSET, GB2312_CHARSET, GREEK_CHARSET, HANGUL_CHARSET,
'      MAC_CHARSET, OEM_CHARSET, RUSSIAN_CHARSET, SHIFTJIS_CHARSET, SYMBOL_CHARSET, TURKISH_CHARSET,
'      VIETNAMESE_CHARSET, JOHAB_CHARSET (Korean language edition of Windows), ARABIC_CHARSET and
'      HEBREW_CHARSET (Middle East language edition of Windows), THAI_CHARSET (Thai language
'      edition of Windows).
'      The OEM_CHARSET value specifies a character set that is operating-system dependent.
'      DEFAULT_CHARSET is set to a value based on the current system locale. For example, when
'      the system locale is English (United States), it is set as ANSI_CHARSET.
'      Fonts with other character sets may exist in the operating system. If an application uses
'      a font with an unknown character set, it should not attempt to translate or interpret
'      strings that are rendered with that font.
'      This parameter is important in the font mapping process. To ensure consistent results,
'      specify a specific character set. If you specify a typeface name in the lfFaceName member,
'      make sure that the lfCharSet value matches the character set of the typeface specified in lfFaceName.
PRIVATE FUNCTION AfxModifyFontSettings (BYVAL hwnd AS HWND, BYVAL nSetting AS LONG, BYVAL nValue AS LONG) AS BOOLEAN
   DIM lfw AS LOGFONTW
   IF IsWindow(hwnd) = 0 THEN EXIT FUNCTION
   IF hCurFont = NULL THEN EXIT FUNCTION
   ' // Change the specified setting
   SELECT CASE nSetting
      CASE AFX_FONT_HEIGHT
         ' // Change the point size
         DIM lPointSize AS LONG = AfxGetFontPointSize(lfw.lfHeight)
         lPointSize = lPointSize * (nValue / 100)
         lfw.lfHeight = -MulDiv(lPointSize, AfxLogPixelsY, 72)
      CASE AFX_FONT_WEIGHT
         ' // Change the font weight
         lfw.lfWeight = nValue
      CASE AFX_FONT_ITALIC
         ' // Change the italic flag
         lfw.lfItalic = CUBYTE(nValue)
      CASE AFX_FONT_UNDERLINE
         ' // Change the underline flag
         lfw.lfUnderline = CUBYTE(nValue)
      CASE AFX_FONT_STRIKEOUT
         ' // Change the strikeout flag
         lfw.lfStrikeOut = CUBYTE(nValue)
      CASE AFX_FONT_CHARSET
         ' // Change the charset
         lfw.lfCharset = CUBYTE(nValue)
      CASE ELSE
         RETURN FALSE
   IF hNewFont = NULL THEN EXIT FUNCTION
   FUNCTION = TRUE
' Creates a logical font.
' Parameters:
' - wszFaceName = The typeface name.
' - lPointSize = The point size.
' - DPI = Dots per inch to calculate scaling. Default value = 96 (no scaling). If you pass -1
'   and the application is DPI aware, the DPI value used by the operating system will be used.
' - lWeight = The weight of the font in the range 0 through 1000. For example, 400 is normal
'      and 700 is bold. If this value is zero, a default weight is used.
' - bItalic = Italic flag. CTRUE or FALSE
' - bUnderline = Underline flag. CTRUE or FALSE
' - bStrikeOut = StrikeOut flag. CTRUE or FALSE
' - bCharset = Charset.
' Return value: The handle of the font or NULL on failure.
' Remarks: The returned font must be destroyed with DeleteObject or the macro DeleteFont
' when no longer needed to prevent memory leaks.
' Usage examples:
'   hFont = AfxCreateFont("MS Sans Serif", 8, , FW_NORMAL, , , , DEFAULT_CHARSET)
'   hFont = AfxCreateFont("Courier New", 10, 96 , FW_BOLD, , , , DEFAULT_CHARSET)
'   hFont = AfxCreateFont("Marlett", 8, -1, FW_NORMAL, , , , SYMBOL_CHARSET)
FUNCTION AfxCreateFont (BYREF wszFaceName AS WSTRING, BYVAL lPointSize AS LONG, BYVAL DPI AS LONG = 96, _
   BYVAL lWeight AS LONG = 0, BYVAL bItalic AS UBYTE = FALSE, BYVAL bUnderline AS UBYTE = FALSE, _
   BYVAL bStrikeOut AS UBYTE = FALSE, BYVAL bCharSet AS UBYTE = DEFAULT_CHARSET) AS HFONT
   DIM tlfw AS LOGFONTW
   DIM hDC AS HDC = GetDC(HWND_DESKTOP)
   ' // Font scaling
   IF DPI = -1 THEN DPI = GetDeviceCaps(hDC, LOGPIXELSX)
   IF DPI > 0 THEN lPointSize = (lPointSize * DPI) \ GetDeviceCaps(hDC, LOGPIXELSY)
   tlfw.lfHeight         = -MulDiv(lPointSize, .GetDeviceCaps(hDC, LOGPIXELSY), 72)  ' logical font height
   tlfw.lfWidth          =  0                                                        ' average character width
   tlfw.lfEscapement     =  0                                                        ' escapement
   tlfw.lfOrientation    =  0                                                        ' orientation angles
   tlfw.lfWeight         =  lWeight                                                  ' font weight
   tlfw.lfItalic         =  bItalic                                                  ' italic(CTRUE/FALSE)
   tlfw.lfUnderline      =  bUnderline                                               ' underline(CTRUE/FALSE)
   tlfw.lfStrikeOut      =  bStrikeOut                                               ' strikeout(CTRUE/FALSE)
   tlfw.lfCharSet        =  bCharset                                                 ' character set
   tlfw.lfOutPrecision   =  OUT_TT_PRECIS                                            ' output precision
   tlfw.lfClipPrecision  =  CLIP_DEFAULT_PRECIS                                      ' clipping precision
   tlfw.lfQuality        =  DEFAULT_QUALITY                                          ' output quality
   tlfw.lfPitchAndFamily =  FF_DONTCARE                                              ' pitch and family
   tlfw.lfFaceName       =  wszFaceName                                              ' typeface name
   ReleaseDC(HWND_DESKTOP, hDC)
   FUNCTION = CreateFontIndirectW(@tlfw)
