Pages: [1] 2 3 ... 5
Author Topic: CWindow RC05  (Read 18847 times)
CWindow RC05
« on: May 02, 2016, 07:21:53 PM »
I have modified CWindow, CXpButton and CPgBar3D to store the pointer to the class in the window extra bytes instead of as a property.
Therefore, instead of using something like
pWindow = CAST(CWindow PTR, GetPropW(hwnd, "CWINDOWPTR"))
that had the inconvenience of having to remember the name of the property ("CWINDOWPTR", etc.), we now will always use something line
pWindow = CAST(CWindow PTR, GetWindowLongPtr(hwnd, 0))
Re: CWindow RC05
« Reply #1 on: May 02, 2016, 07:26:38 PM »
And these are the modified OOP versions of the progress bar sample programs.
Re: CWindow RC05 - Split button example
« Reply #2 on: May 03, 2016, 12:27:27 AM »
A split button is a button with a drop down arrow. It is available with Windows Vista+ and needs the use of a manifest because we need to use version 6 of the Windows Common Controls. It also supports the use of an imagelist to display icons.
To make the size of the icon DPI aware, I have used this formula:
   ' // Calculate an appropriate icon size
   DIM cx AS LONG = 16 * pWindow.DPI \ 96
based in that 16 pixels is the normal icon size for 96 DPI.
Remember to link a resource file that includes a manifest and remember also to change the path and name of the icon.
' Microsoft Windows
' File: CW_SplitButton.fbtpl
' Contents: CWindow with a split button
#define unicode
#define _WIN32_WINNT &h0602
#INCLUDE ONCE "windows.bi"
#INCLUDE ONCE "Afx/AfxGdiplus.inc"
' // You must link a resource file that includes a manifest
' $FB_RESPATH = "FBRES.rc"
USING Afx.CWindowClass
USING Afx.Gdiplus
CONST IDC_MENUCOMMAND1 = 28000
CONST IDC_MENUCOMMAND2 = 28001
' Window procedure
   DIM hDC AS HDC
   DIM pPaint AS PAINTSTRUCT
   DIM rc AS RECT
   DIM pWindow AS CWindow PTR
   SELECT CASE uMsg
      CASE WM_CREATE
      CASE WM_COMMAND
         SELECT CASE LOWORD(wParam)
            CASE IDCANCEL
      CASE WM_NOTIFY
         ' // Processs notify messages sent by the split button
         DIM pNmh AS NMHDR PTR = CAST(NMHDR PTR, lParam)
         IF pNmh->idFrom = IDCANCEL AND pNmh->code = BCN_DROPDOWN THEN
            DIM pDropDown AS NMBCDROPDOWN PTR = CAST(NMBCDROPDOWN PTR, lParam)
            ' // Get screen coordinates of the button
            DIM pt AS POINT = (pDropdown->rcButton.left, pDropDown->rcButton.bottom)
            ClientToScreen(pNmh->hwndFrom, @pt)
            ' // Create a menu and add items
            DIM hSplitMenu AS HMENU = CreatePopupMenu
            AppendMenuW(hSplitMenu, MF_BYPOSITION, IDC_MENUCOMMAND1, "Menu item 1")
            AppendMenuW(hSplitMenu, MF_BYPOSITION, IDC_MENUCOMMAND2, "Menu item 2")
            ' // Display the menu
            TrackPopupMenu(hSplitMenu, TPM_LEFTALIGN OR TPM_TOPALIGN, pt.x, pt.y, 0, hwnd, NULL)
            FUNCTION = CTRUE
      CASE WM_SIZE
            ' // Resize the button
            pWindow->MoveWindow GetDlgItem(hwnd, IDCANCEL), pWindow->ClientWidth - 200, pWindow->ClientHeight - 90, 110, 23, CTRUE
    CASE WM_DESTROY
         ImageList_Destroy CAST(HIMAGELIST, SendMessageW(GetDlgItem(hwnd, IDCANCEL), TB_SETIMAGELIST, 0, 0))
         PostQuitMessage(0)
' Main
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   pWindow.Create(NULL, "CWindow with a split button", @WndProc)
   pWindow.SetClientSize(300, 150)
   pWindow.Center
   ' // Add a button without position or size (it will be resized in the WM_SIZE message).
   DIM hSplitButton AS HWND = pWindow.AddControl("Button", pWindow.hWindow, IDCANCEL, _
      "&Shutdown", , , , , WS_CHILD OR WS_VISIBLE OR WS_TABSTOP OR BS_CENTER OR BS_VCENTER OR BS_SPLITBUTTON)
   ' // Create an image list for the button
   DIM hImageList AS HIMAGELIST = ImageList_Create(cx, cx, ILC_COLOR32 OR ILC_MASK, 1, 0)
   ' // Remember to change the path and name of the icon
   IF hImageList THEN ImageList_ReplaceIcon(hImageList, -1, AfxGdipImageFromFile(ExePath & "\Shutdown_48.png"))
   ' // Fill a BUTTON_IMAGELIST structure and set the image list
   DIM bi AS BUTTON_IMAGELIST = (hImageList, (3, 3, 3, 3), BUTTON_IMAGELIST_ALIGN_LEFT)
   SendMessageW hSplitButton, BCM_SETIMAGELIST, 0, CAST(LPARAM, @bi)
   ' // Process windows events
« Last Edit: May 03, 2016, 12:29:36 AM by Jose Roca »
Re: CWindow RC05
« Reply #3 on: May 03, 2016, 12:43:59 AM »
Thanks to the functions included in AfxGdiplus.inc, we don't need to have a set of different icon sizes for each DPI setting. We can have a 48 or 64 icon and create the image list with the appropriate width and height using the formula: DIM cx AS LONG = 16 * pWindow.DPI \ 96.
Note that, unlike LoadImage, you don't have to specify the wanted dimensions of the icon when using the AfxGdipxxx functions that create the icon from a .png file, only when calling ImageList_Create.
By using a manifest, the alpha channel is preserved; otherwise, it is lost, because versions of the common controls library below 6 don't support the alpha channel.
Re: CWindow RC05
« Reply #4 on: May 03, 2016, 12:47:12 AM »
I also like this FreeBasic shortcut to fill structures:
The structure is as follows:
type BUTTON_IMAGELIST
himl as HIMAGELIST
margin as RECT
uAlign as UINT
end type
The (3, 3, 3, 3) in the assignment allows to fill the embedded RECT structure. Nice.
Re: CWindow RC05
« Reply #5 on: May 03, 2016, 12:36:08 PM »
The new cWindow class is looking awesome! Finally a great new Windows based framework for FreeBASIC.
I am just thinking out loud at this point, but I can see new users having no trouble creating windows and adding controls, however, I can see users having trouble dealing with the notifications/events from those windows/controls. Just as PowerBASIC users do not take the time to learn the meanings of wParam and lParam values for notifications, I can see FreeBASIC users having the same lack of interest. I wonder if eventually you might want to consider creating message crackers similar to how the old style C programmers used to deal with the WinAPI. It would also ensure that messages are cracked correctly between 32 and 64 bit.
Basically, maybe start creating examples using the handlers found in windowsx.bi
Then have separate functions setup to respond to those macros: like, OnCreate, OnSize, OnDestroy, etc...
It would help hide all of the messy CAST, LOWORD, HIWORD, stuff, and make the code much more "approachable" and structured for newbies.
Just a thought.
Re: CWindow RC05
« Reply #6 on: May 03, 2016, 02:18:38 PM »
I never have liked to use message crackers. But the main reason is that, since FB doesn't remove dead code, I want to keep the class as lightweight as possible. Even some of the auxiliary code will eventually end in separate include files.
But these classes are not like PB classes. You can simply extend it and do wathever you like.
MyClsWindow EXTENDS CWindow
and pass to it a pointer to your new window procedure, and replace the DoEvents procedure with your own, and/or override methods, etc.
This way, CWindow will provide the basic stuff and you can add all the bloat you like.
BTW many of these messy CAST, LOWORD, HIWORD, stuff can be solved with defines or macros. windowsx.bi already has many of them, such GET_X_LPARAM, GET_Y_LPARAM, etc. I will try to learn more about FB macros. Until now I have mainly written test code.
I think that the last version of CWindow can already be used for production code. It does a lot of things with little overhead. DPI and Unicode aware, MDI support, works with 32 and 64 bit without changes, etc. And see how easily I have extended it in the CTabPage class to provide support for tab pages.
Re: CWindow RC05
« Reply #7 on: May 03, 2016, 04:35:17 PM »
There are convenient defines in windowsx.bi that I will begin to use, such DeleteFont or SelectFont.
DeleteObject(CAST(HGDIOBJ, hNewFont))
I will use
DeleteFont(hNewFont)
or instead of
SelectObject(hDC, CAST(HGDIOBJ, CAST(HFONT, hOldFont)))
I will use
SelectFont(hDC, hOldFont)
They're convenient because they hide these nasty casts.
But using defines for Windows messages can be more problematic, because the MSDN documentation talks about HIWORD of wParam, not about GET_WM_COMMAND_CMD or something like that.
Re: CWindow RC05
« Reply #8 on: May 03, 2016, 04:55:38 PM »
Don't undestand.
If I try to replace
IF hNewFont THEN DeleteObject(CAST(HGDIOBJ, hNewFont))
with
IF hNewFont THEN DeleteFont(hNewFont)
I get a syntax error.
Error 17: Syntax error. Found 'hNewFont' in 'IF hNewFont THEN DeleteFont(hNewFont)'.
DeleteFont is defined as
#define DeleteFont(hfont) DeleteObject(cast(HGDIOBJ, cast(HFONT, (hfont))))
in windowsx.bi
James Fuller
Re: CWindow RC05
« Reply #9 on: May 03, 2016, 05:20:14 PM »
Jose,
  It probably isn't this but I NEVER use single line IF THEN statements.
James
Re: CWindow RC05
« Reply #10 on: May 03, 2016, 05:36:02 PM »
If doesn't matter if I use one line or
         IF hNewFont NULL THEN
or
         IF hNewFont <> NULL THEN
Where is the syntax error?
Re: CWindow RC05
« Reply #11 on: May 03, 2016, 05:43:39 PM »
The easier way to avoid that casting mess would be, of course, to remove that irritant strict type checking from the compiler. It is impossible to write a couple of lines of API code without having to use CAST. I wonder if the writers of the compiler use it to write applications. Probably they use C++.
« Last Edit: May 03, 2016, 05:45:59 PM by Jose Roca »
Re: CWindow RC05
« Reply #12 on: May 03, 2016, 05:48:24 PM »
I think it has to do with the #define using the hfont variable as part of the expansion. Maybe because hfont is a defined structure in FB.
I changed the declare to the following and it worked:
#Define DeleteFont(_hfont) DeleteObject(Cast(HGDIOBJ, Cast(HFONT, (_hfont)) ))
If this is the case then I can post on the FB forum to get a more definitive answer.
Re: CWindow RC05
« Reply #13 on: May 03, 2016, 05:49:07 PM »
Something frequently asked. How to make a modal popup window?
' Microsoft Windows
' File: CW_PopupWindow.fbtpl
' Contents: CWindow with a modal popup window
#define unicode
CONST IDC_POPUP = 1001
DECLARE FUNCTION WndProc (BYVAL hWnd AS HWND, BYVAL uMsg AS UINT, BYVAL wParam AS WPARAM, BYVAL lParam AS LPARAM) AS LRESULT
DECLARE FUNCTION PopupWindow (BYVAL hParent AS HWND) AS LONG
DECLARE FUNCTION PopupWndProc (BYVAL hWnd AS HWND, BYVAL uMsg AS UINT, BYVAL wParam AS WPARAM, BYVAL lParam AS LPARAM) AS LRESULT
' Main
   pWindow.Create(NULL, "CWindow with a popup window", @WndProc)
   pWindow.Center
   pWindow.AddControl("Button", pWindow.hWindow, IDC_POPUP, "&Popup", 350, 250, 75, 23)
' Window procedure
   DIM hDC AS HDC
   DIM rc AS RECT
   SELECT CASE uMsg
      CASE WM_CREATE
      CASE WM_COMMAND
            CASE IDCANCEL
            CASE IDC_POPUP
                  PopupWindow(hwnd)
      CASE WM_SIZE
            ' // Resize the buttons
            pWindow->MoveWindow GetDlgItem(hwnd, IDCANCEL), pWindow->ClientWidth - 120, pWindow->ClientHeight - 50, 75, 23, CTRUE
    CASE WM_DESTROY
         PostQuitMessage(0)
' Popup window procedure
   pWindow.Create(hParent, "Popup window", @PopupWndProc, , , , , _
      WS_VISIBLE OR WS_CAPTION OR WS_POPUPWINDOW OR WS_THICKFRAME, WS_EX_WINDOWEDGE)
   pWindow.Brush = GetStockObject(WHITE_BRUSH)
   pWindow.SetClientSize(300, 200)
   pWindow.Center(pWindow.hWindow, hParent)
   ' / Process Windows messages
   DIM hOldFont AS HFONT
   STATIC hNewFont AS HFONT
   SELECT CASE uMsg
      CASE WM_CREATE
         ' // Get a pointer to the CWindow class from the CREATESTRUCT structure
         DIM pCreateStruct AS CREATESTRUCT PTR = CAST(CREATESTRUCT PTR, lParam)
         DIM pWindow AS CWindow PTR = CAST(CWindow PTR, pCreateStruct->lpCreateParams)
         ' // Create a new font scaled according the DPI ratio
         IF pWindow->DPI <> 96 THEN hNewFont = pWindow->CreateFont("Tahoma", 9)
         ' Disable parent window to make popup window modal
         EnableWindow GetParent(hwnd), FALSE
      CASE WM_COMMAND
            CASE IDCANCEL
      CASE WM_PAINT
    DIM rc AS RECT, ps AS PAINTSTRUCT, hDC AS HANDLE
         hDC = BeginPaint(hWnd, @ps)
         IF hNewFont THEN hOldFont = CAST(HFONT, SelectObject(hDC, CAST(HGDIOBJ, hNewFont)))
         GetClientRect(hWnd, @rc)
         DrawTextW(hDC, "Hello, World!", -1, @rc, DT_SINGLELINE or DT_CENTER or DT_VCENTER)
         IF hNewFont THEN SelectObject(hDC, CAST(HGDIOBJ, CAST(HFONT, hOldFont)))
         EndPaint(hWnd, @ps)
      CASE WM_CLOSE
         ' // Enables parent window keeping parent's zorder
         EnableWindow GetParent(hwnd), CTRUE
         ' // Don't exit; let DefWindowProcW perform the default action
    CASE WM_DESTROY
         ' // Destroy the new font
         PostQuitMessage(0)
« Last Edit: May 03, 2016, 05:57:15 PM by Jose Roca »
Re: CWindow RC05
« Reply #14 on: May 03, 2016, 05:52:40 PM »
That is. As always, macros are a can of worms.
