CWindow RC05
Started by José Roca, May 02, 2016, 07:51:53 PM
Ah yes, probably because in the first case it is treated as a type/class initializer (constructor) whereas in the second case it is just a simple assignment.
Is RC5 good enough now to create a full application with? Tomorrow I was going to try to create a new application somewhat similar to this one:  http://www.codeproject.com/Articles/4948/Message-Cracker-Wizard-for-Win-SDK-Developers
I was going to use that application to see if I encounter any issues with RC5.
Yes, it is.
Anyway, the attached file contains the latest version. I only have removed a couple of auxiliary functions to add toolbar buttons because now that I have discovered that declaring the procedure PRIVATE unused procedures are not included in the code. Therefore, I'm going to adapt my PowerBASIC wrappers to FB.
Jose, have you tried creating an accelerator table yet? I tried but it looks like there may be a problem.
   '  Create the accelerator table for the menu
   pWindow->AddAccelerator( FNOINVERT Or FVIRTKEY Or FALT,     VK_F4, IDM_EXIT )
   pWindow->AddAccelerator( FNOINVERT Or FVIRTKEY Or FCONTROL, VK_M,  IDM_COPYMACRO )
   pWindow->AddAccelerator( FNOINVERT Or FVIRTKEY Or FCONTROL, VK_F,  IDM_COPYFUNCTION )
   pWindow->AddAccelerator( FNOINVERT Or FVIRTKEY Or FCONTROL, VK_L,  IDM_MSGFILTERS )
   pWindow->CreateAcceleratorTable()
I think that it might have to do with ReDim'ing of the m_rgAccelEntries() type array. The ubound does not increase between calls to AddAccelerator.
I am investigating the code now.
Looks you made a typo in your Type definition for the m_rgAccelEntries array in the CWindow definition (CWindow.inc)
You used HACCEL and it should be ACCEL
      Dim m_rgAccelEntries(Any) As ACCEL
You're right. The only features that I haven't yet tested are accelerator keys and the BITMAP/ICON LABEL, BITMAP/ICON BUTTON.
Now that I know that unused private procedures aren't included in the code, I'm going to begin to write useful wrappers. For Common Controls, since there are already a lot of defines in Windowsx.bi and commctrl.bi, I will only write the ones that require lenghty code instead of a call to SendMessage.
I have begin with the ones related with DPI:
'                              *** DPI RELATED PROCEDURES ***
' Sets the current process as dots per inch (dpi) aware.
' Note: SetProcessDPIAware is subject to a possible race condition if a DLL caches dpi
' settings during initialization. For this reason, it is recommended that dpi-aware be set
' through the application (.exe) manifest rather than by calling SetProcessDPIAware.
' Return value: TRUE on success; FALSE on failure.
PRIVATE FUNCTION AfxSetProcessDPIAware () AS BOOLEAN
   DIM AS ANY PTR pLib = DyLibLoad("user32.dll")
   IF pLib = 0 THEN EXIT FUNCTION
   DIM pProc AS FUNCTION () AS LONG
   pProc = DyLibSymbol(pLib, "SetProcessDPIAware")
   IF pProc = 0 THEN EXIT FUNCTION
   FUNCTION = pProc()
   DyLibFree(pLib)
' Determines whether the current process is dots per inch (dpi) aware such that it adjusts
' the sizes of UI elements to compensate for the dpi setting.
' Return value: TRUE or FALSE
PRIVATE FUNCTION AfxIsProcessDPIAware () AS BOOLEAN
   pProc = DyLibSymbol(pLib, "IsProcessDPIAware")
   FUNCTION = pProc()
   DyLibFree(pLib)
' Retrieves the value of the UseDpiScaling setting (Vista/Windows 7+).
' Returns TRUE if the OS uses DPI scaling; FALSE otherwise.
PRIVATE FUNCTION AfxUseDpiScaling () AS BOOLEAN
   DIM hkRes AS HKEY, dwType AS DWORD, dwData AS DWORD, cbData AS DWORD
   IF RegOpenKeyExW(HKEY_CURRENT_USER, "Software\Microsoft\Windows\DWM", 0, KEY_QUERY_VALUE, @hkRes) = ERROR_SUCCESS THEN
      IF hkRes THEN
         cbData = SIZEOF(cbData)
         DIM hr AS LONG = RegQueryValueExW(hkRes, "UseDpiScaling", 0, @dwType, CPTR(BYTE PTR, @dwData), @cbData)
         RegCloseKey hkRes
         IF hr = ERROR_SUCCESS THEN FUNCTION = (dwData <> 0)
' Retrieves the number of pixels per logical inch along the screen width of the desktop
' window. In a system with multiple display monitors, this value is the same for all monitors.
PRIVATE FUNCTION AfxLogPixelsX () AS LONG
   DIM hDC AS HDC = GetDC(HWND_DESKTOP)
   DIM dpiX AS LONG = GetDeviceCaps(hDC, LOGPIXELSX)
   ReleaseDC HWND_DESKTOP, hDC
   FUNCTION = dpiX
' Retrieves the number of pixels per logical inch along the screen height of the desktop
PRIVATE FUNCTION AfxLogPixelsY () AS LONG
   DIM dpiY AS LONG = GetDeviceCaps(hDC, LOGPIXELSY)
   FUNCTION = dpiY
' Retrieves the desktop horizontal scaling ratio.
PRIVATE FUNCTION AfxScaleRatioX () AS SINGLE
   DIM rxRatio AS SINGLE = (GetDeviceCaps(hDC, LOGPIXELSX) / 96)
   FUNCTION = rxRatio
' Retrieves the desktop vertical scaling ratio.
PRIVATE FUNCTION AfxScaleRatioY () AS SINGLE
   DIM ryRatio AS SINGLE = (GetDeviceCaps(hDC, LOGPIXELSY) / 96)
   FUNCTION = ryRatio
' Scales an horizontal coordinate according the DPI (dots per pixel) being used by the desktop.
PRIVATE FUNCTION AfxScaleX (BYVAL cx AS SINGLE) AS SINGLE
   FUNCTION = cx * (GetDeviceCaps(hDC, LOGPIXELSX) / 96)
' Scales a vertical coordinate according the DPI (dots per pixel) being used by the desktop.
PRIVATE FUNCTION AfxScaleY (BYVAL cy AS SINGLE) AS SINGLE
   FUNCTION = cy * (GetDeviceCaps(hDC, LOGPIXELSY) / 96)
' Unscales an horizontal coordinate according the DPI (dots per pixel) being used by the desktop.
PRIVATE FUNCTION AfxUnscaleX (BYVAL cx AS SINGLE) AS SINGLE
   FUNCTION = cx / (GetDeviceCaps(hDC, LOGPIXELSX) / 96)
' Unscales a vertical coordinate according the DPI (dots per pixel) being used by the desktop.
PRIVATE FUNCTION AfxUnscaleY (BYVAL cy AS SINGLE) AS SINGLE
   FUNCTION = cy / (GetDeviceCaps(hDC, LOGPIXELSY) / 96)
' Determines if screen resolution meets minimum requirements.
' Parameters:
' - cxMin = Minimum screen resolution width in pixels.
' - cxMin = Minimum screen resolution height in pixels.
' Return value: TRUE or FALSE.
PRIVATE FUNCTION AfxIsResolutionAtLeast (BYVAL cxMin AS LONG, BYVAL cyMin AS LONG) AS BOOLEAN
   DIM ScreenWidth AS LONG = GetSystemMetrics(SM_CXSCREEN)
   DIM ScreenHeight AS LONG = GetSystemMetrics(SM_CYSCREEN)
   IF (cxMin <= ScreenWidth) AND (cyMin <= ScreenHeight) THEN FUNCTION = TRUE
' Determines if screen resolution meets minimum requirements in relative pixels,
' e.g. for a screen resolution of 1920x1080 pixels and a DPI of 192 (scaling ratio = 2),
' the maximum relative pixels for a DPI aware application is 960x540.
' - cxMin = Minimum screen resolution width in relative pixels.
' - cxMin = Minimum screen resolution height in relative pixels.
PRIVATE FUNCTION AfxIsDPIResolutionAtLeast (BYVAL cxMin AS LONG, BYVAL cyMin AS LONG) AS BOOLEAN
   ' // Get de DPI values used by the desktop window
   ' // Scale the values
   cxMin = cxMin * dpiX / 96
   cyMin = cyMin * dpiX / 96
   ' // Calculate the width and height of the primary display monitor, in pixels
#52
For GDI+, I will add functions that deal with bitmaps and a function that loads textures suitable to be used with OPENGL.
For the ones that need COM, i first have to translate some headers.
We could do it faster it we had betatesters.
#53
Metric conversions.
'                                *** METRIC CONVERSIONS ***
' Converts from HiMetric to Pixels
' Note: HiMetric is a scaling unit similar to twips used in computing. It is one
' thousandth of a centimeter and is independent of the screen resolution.
' HiMetric per inch = 2540   ' 1 inch = 2.54 mm
' Horizontal resolution
PRIVATE FUNCTION AfxHiMetricToPixelsX (BYVAL hm AS LONG) AS LONG
   DIM nPixelsPerLogicalInchX AS LONG = GetDeviceCaps(hDC, LOGPIXELSX)
   ReleaseDC(HWND_DESKTOP, hDC)
   FUNCTION = MulDiv(hm, nPixelsPerLogicalInchX, 2540)
' Vertical resolution
PRIVATE FUNCTION AfxHiMetricToPixelsY (BYVAL hm AS LONG) AS LONG
   DIM nPixelsPerLogicalInchY AS LONG = GetDeviceCaps(hDC, LOGPIXELSY)
   FUNCTION = MulDiv(hm, nPixelsPerLogicalInchY, 2540)
' Converts from Pixels to HiMetric
PRIVATE FUNCTION AfxPixelsToHiMetricX (BYVAL cx AS LONG) AS LONG
   FUNCTION = MulDiv(cx, 2540, nPixelsPerLogicalInchX)
PRIVATE FUNCTION AfxPixelsToHiMetricY (BYVAL cy AS LONG) AS LONG
   FUNCTION = MulDiv(cy, 2540, nPixelsPerLogicalInchY)
' Converts pixels to point size (1/72 of an inch).
PRIVATE FUNCTION AfxPixelsToPointsX (BYVAL pix AS LONG) AS LONG
   DIM LPX AS LONG = GetDeviceCaps(hDC, LOGPIXELSX)
   FUNCTION = pix * 72 / LPX
PRIVATE FUNCTION AfxPixelsToPointsY (BYVAL pix AS LONG) AS LONG
   DIM LPY AS LONG = GetDeviceCaps(hDC, LOGPIXELSY)
   FUNCTION = pix * 72 / LPY
' Converts a point size (1/72 of an inch) to pixels. Horizontal resolution.
PRIVATE FUNCTION AfxPointsToPixelsX (BYVAL pts AS LONG) AS LONG
   FUNCTION = MulDiv(pts, LPX, 72)
PRIVATE FUNCTION AfxPointsToPixelsY (BYVAL pts AS LONG) AS LONG
   FUNCTION = MulDiv(pts, LPY, 72)
' Converts pixels to twips.
' Twips are screen-independent units to ensure that the proportion of screen elements are
' the same on all display systems. A twip is defined as being 1/1440 of an inch.
PRIVATE FUNCTION AfxPixelsToTwipsX (BYVAL nPixels AS LONG) AS LONG
   FUNCTION = (nPixels * 1440) / LPX
' Vertical resolution.
PRIVATE FUNCTION AfxPixelsToTwipsY (BYVAL nPixels AS LONG) AS LONG
   FUNCTION = (nPixels * 1440) / LPY
' Converts twips to pixels.
PRIVATE FUNCTION AfxTwipsToPixelsX (BYVAL nTwips AS LONG) AS LONG
   FUNCTION = (nTwips / 1440) * LPX
PRIVATE FUNCTION AfxTwipsToPixelsY (BYVAL nTwips AS LONG) AS LONG
   FUNCTION = (nTwips / 1440) * LPY
' Returns the width of a pixel, in twips.
' Pixel dimensions can vary between systems and may not always be square, so separate
' functions for pixel width and height are required.
PRIVATE FUNCTION AfxTwipsPerPixelX () AS LONG
   FUNCTION = 1440 / LPX
PRIVATE FUNCTION AfxTwipsPerPixelY () AS LONG
   FUNCTION = 1440 / LPY
An additional one:
' Converts point size to DIP (device independent pixel).
' DIP is defined as 1/96 of an inch and a point is 1/72 of an inch.
FUNCTION AfxPointSizeToDip (BYVAL ptsize AS SINGLE) AS SINGLE
   FUNCTION = (ptsize / 72) * 96
Quote from: Jose Roca on May 06, 2016, 03:09:50 PM
We could do it faster it we had beta testers.
I totally agree.  ;)
I am writing my first application with your code. Pretty straight forward so far. I can say that I totally HATE having to position controls via code  :-)   It reminds me of the days when I first bought PB and had to hand code DDT. Certainly makes me appreciate FireFly for the visual positioning of controls.
I will continue to report any issues that I encounter. The keyboard accelerators was the only one so far but it is all working now.
Clipboard functions:
'                                    *** CLIPBOARD ***
' Clears the contents of the clipboard.
' Return Value
'   If the function succeeds, the return value is nonzero.
'   If the function fails, the return value is zero.
PRIVATE FUNCTION AfxClearClipboard () AS LONG
   ' // Opens the clipboard
   IF OpenClipboard(NULL) <> 0 THEN
      ' // Empties the clipboard
      FUNCTION = EmptyClipboard
      ' // Closes the clipboard
      CloseClipboard
' Retrieves data from the clipboard in the specified format.
' Parameter
'   cfFormat = Clipboard format.
' Return Value
'   If the function succeeds, the return value is the handle to the data.
'   If the function fails, the return value is NULL.
PRIVATE FUNCTION AfxGetClipboardData (BYVAL cfFormat AS DWORD) AS HGLOBAL
   DIM hSource AS HANDLE
      ' // Retrieves data from the clipboard in the specified format
      hSource = GetClipboardData(cfFormat)
      CloseClipboard
      ' // Exits on failure
      IF hSource = NULL THEN EXIT FUNCTION
   ' // Gets the size of the specified global memory object, in bytes
   DIM dwSize AS SIZE_T_ = GlobalSize(hSource)
   IF dwSize = 0 THEN EXIT FUNCTION
   ' // Gets a pointer to the source memory object
   DIM pSource AS LPVOID = GlobalLock(hSource)
   IF pSource = NULL THEN EXIT FUNCTION
   ' // Allocates the specified number of bytes from the heap
   DIM hDest AS HGLOBAL = GlobalAlloc(GHND_, dwSize)
   IF hDest = NULL THEN
      ' // Unlocks the source memory object
      GlobalUnlock hSource
   ' // Gets a pointer to the destination memory object
   DIM pDest AS LPVOID = GlobalLock(hDest)
   IF pDest = NULL THEN
      ' // Frees the allocated memory block
      GlobalFree hDest
   ' // Copies the data from the source to the destination
   memcpy pDest, pSource, dwSize
   ' // Unlocks the destination memory object
   GlobalUnlock hDest
   ' // Returns the handle to the data
   FUNCTION = hDest
' Places a data object into the clipboard.
' Parameters
'   hData    = Handle to the data in the specified format.
' Return Value
' Remarks
'   The application must not use the hData handle once it has called the AfxSetClipboardData function.
PRIVATE FUNCTION AfxSetClipboardData (BYVAL cfFormat AS DWORD, BYVAL hData AS HANDLE) AS HANDLE
      EmptyClipboard
      ' // Places the data object in the clipboard
      FUNCTION = SetClipboardData(cfFormat, hData)
      CloseClipboard
' Returns a text string from the clipboard.
PRIVATE FUNCTION AfxGetClipboardTextA () AS STRING
   ' // If the text format is available...
   IF IsClipboardFormatAvailable(CF_TEXT) <> 0 THEN
         ' // Gets memory object of clipboard text
         DIM hMem AS HANDLE = GetClipboardData(CF_TEXT)
         IF hMem <> NULL THEN
            ' // Locks it and get a pointer
            DIM pMem AS HGLOBAL = GlobalLock(hMem)
            ' // Assigns the data to our function return value
            IF pMem <> NULL THEN FUNCTION = *CAST(ZSTRING PTR, pMem)
            ' // Releases the memory object
            GlobalUnlock hMem
         CloseClipboard
' Returns a unicode text string from the clipboard.
' Usage:
' DIM pwsz AS WSTRING PTR
' pwsz = AfxGetClipboardTextW
' MessageBoxW 0, *pwsz, "", MB_OK
' IF pwsz THEN Delete(pwsz)
PRIVATE FUNCTION AfxGetClipboardTextW () AS WSTRING PTR
   IF IsClipboardFormatAvailable(CF_UNICODETEXT) <> 0 THEN
         DIM hMem AS HANDLE = GetClipboardData(CF_UNICODETEXT)
               ' // Gets the size of the global lock
               DIM dwSize AS DWORD = GlobalSize(hMem)
               IF dwSize > 0 THEN
                  ' // Allocates a buffer and copies the contents of the clipboard to it
                  DIM pBuffer AS WSTRING PTR = CAllocate(dwSize, 1)
                  memcpy(pBuffer, pMem, dwSize)
                  FUNCTION = pBuffer
            GlobalUnlock hMem
         CloseClipboard
#ifdef UNICODE
   #define AfxGetClipboardText AfxGetClipboardTextW
#else
   #define AfxGetClipboardText AfxGetClipboardTextA
#endif
' Places a text string into the clipboard.
' Parameter
'   strText = Text to place in the clipboard.
' Return Value
PRIVATE FUNCTION AfxSetClipboardTextA (BYVAL strText AS STRING) AS HANDLE
      EmptyClipboard
      ' // Allocates a global memory block
      DIM hMem AS HGLOBAL = GlobalAlloc(GMEM_MOVEABLE OR GMEM_DDESHARE, LEN(strText) + 1)
         ' // Locks it and gets a pointer to the memory location
         DIM pMem AS LPVOID = GlobalLock(hMem)
         ' // Copies the text into the allocated memory block
         IF pMem <> NULL THEN *CAST(ZSTRING PTR, pMem) = strText & CHR(0)
         ' // Unlocks the memory block
         GlobalUnlock hMem
         ' // Places the text in the clipboard
         DIM hData AS HANDLE = SetClipboardData(CF_TEXT, hMem)
         IF hData <> NULL THEN
            ' // Returns the handle of the data
            FUNCTION = hData
            ' // Frees the memory block
            GlobalFree hMem
      CloseClipboard
' Places a unicode text string into the clipboard.
' Parameter
'   wszText = Text to place in the clipboard.
' Return Value
PRIVATE FUNCTION AfxSetClipboardTextW (BYREF wszText AS WSTRING) AS HANDLE
      EmptyClipboard
      DIM hMem AS HGLOBAL = GlobalAlloc(GMEM_MOVEABLE OR GMEM_DDESHARE, (LEN(wszText) + 1) * 2)
         IF pMem <> NULL THEN *CAST(WSTRING PTR, pMem) = wszText & CHR(0, 0)
         GlobalUnlock hMem
         DIM hData AS HANDLE = SetClipboardData(CF_UNICODETEXT, hMem)
            FUNCTION = hData
            GlobalFree hMem
      CloseClipboard
#ifdef UNICODE
   #define AfxSetClipboardText AfxSetClipboardTextW
#else
   #define AfxSetClipboardText AfxSetClipboardTextA
#endif
I did not use FireFly for PB because it was not unicode aware.
I also like to code by hand because I don't write many applications and mostly of my code is testing code. If I'm doing all this work it is because I like to investigate and experiment. It is more fun than playing cards with other retirees.
I only have a monitor, so I can't test this one:
' If you use dual (or even triple/quad) displays then you have undoubtedly encountered the
' following situation: You change the physical order of your displays, or otherwise
' reconfigure the logical ordering using your display software. This sometimes has the
' side-effect of changing your desktop coordinates from zero-based to negative starting
' coordinates (i.e. the top-left coordinate of your desktop changes from 0,0 to -1024,-768).
' This effects many Windows programs which restore their last on-screen position whenever
' they are started. Should the user reorder their display configuration this can sometimes
' result in a Windows program subsequently starting in an off-screen position (i.e. at a
' location that used to be visible) - and is now effectively invisible, preventing the
' user from closing it down or otherwise moving it back on-screen.
' The ForceVisibleDisplay function can be called at program start-time right after the
' main window has been created and positioned 'on-screen'. Should the window be positioned
' in an off-screen position, it is forced back onto the nearest display to its last
' position. The user will be unaware this is happening and won't even realise to thank you
' for keeping their user-interface visible, even though they changed their display
' settings.
' Source: http://www.catch22.net/tuts/tips2
PRIVATE SUB AfxForceVisibleDisplay (BYVAL hwnd AS HWND)
   ' // Check if the specified window-recrangle is visible on any display
   DIM rc AS RECT
   GetWindowRect(hwnd, @rc)
   IF MonitorFromRect(@rc, MONITOR_DEFAULTTONULL) <> NULL THEN EXIT SUB
   ' // Find the nearest display to the rectangle
   DIM hMonitor AS HMONITOR
   DIM mi AS MONITORINFO
   mi.cbSize = SIZEOF(mi)
   hMonitor = MonitorFromRect(@rc, MONITOR_DEFAULTTONEAREST)
   GetMonitorInfoW(hMonitor, @mi)
   ' // Center window rectangle
   rc.left = mi.rcWork.left + ((mi.rcWork.right - mi.rcWork.left) - (rc.right-rc.left)) \ 2
   rc.top = mi.rcWork.top + ((mi.rcWork.bottom - mi.rcWork.top) - (rc.bottom-rc.top)) \ 2
   SetWindowPos(hwnd, 0, rc.left, rc.top, 0, 0, SWP_NOACTIVATE OR SWP_NOZORDER OR SWP_NOSIZE)
This one has revealed a problem that I was having. If I use DIM hwndForeground AS HWND, the compiler gives an error, but if I use DIM hwndForeground AS .HWND, it compiles fine.
Therefore, in CWindow I have changed
#ifdef USEMDI
   ' // Note: I have needed to use HANDLE instead of HWND; otherwise, the compiler
   ' // gives error 14: Branch crossing local variable definition. Don't know why.
   STATIC hwndClient AS HANDLE    ' // Handle of the MDI client window
   DIM    hwndActive AS HANDLE    ' // Active window
   DIM    hMdi AS HANDLE         ' // MDI child window handle
   ' // MDI client window handle
   IF hwndClient = NULL AND pWindow <> NULL THEN hwndClient = pWindow->hwndClient
#endif
to
#ifdef USEMDI
   STATIC hwndClient AS .HWND    ' // Handle of the MDI client window
   DIM    hwndActive AS .HWND    ' // Active window
#endif
' Brings the thread that created the specified window into the foreground and activates
' the window. Keyboard input is directed to the window, and various visual cues are changed
' for the user. The system assigns a slightly higher priority to the thread that created
' the foreground window than it does to other threads.
' Replacement for the SetForegroundWindow API function, that sometimes fails.
SUB AfxForceSetForegroundWindow (BYVAL hwnd AS HWND)
   DIM dwProcessId AS DWORD
   DIM hwndForeground AS .HWND = GetForegroundWindow
   DIM dwThreadId AS DWORD = GetWindowThreadProcessId(hwndForeground, @dwProcessId)
   DIM dwCurThreadId AS DWORD = GetCurrentThreadId
   AttachThreadInput(dwCurThreadId, dwThreadId, CTRUE)
   SetForegroundWindow(hwnd)
   BringWindowToTop(hwnd)
   SetFocus(hwnd)
   AttachThreadInput(dwCurThreadId, dwThreadId, FALSE)
Menu wrapper functions.
'                                      *** MENU ***
' Checks a menu item.
' - hMenu = A handle to the menu that contains the menu item.
' - uItem = The identifier or position of the menu item to get information about.
'           The meaning of this parameter depends on the value of fByPosition.
' - fByPosition = The meaning of uItem. If this parameter is FALSE, uItem is a menu item
'           identifier. Otherwise, it is a menu item position.
' Return Value: The return value specifies the previous state of the menu item (either
' MF_CHECKED or MF_UNCHECKED). If the menu item does not exist, the return value is -1.
PRIVATE FUNCTION AfxCheckMenuItem (BYVAL hMenu AS HMENU, BYVAL uItem AS DWORD, BYVAL fByPosition AS LONG = FALSE) AS DWORD
   DIM dwFlags AS DWORD
   IF fByPosition THEN dwFlags = MF_BYPOSITION ELSE dwFlags = MF_BYCOMMAND
   dwFlags = dwFlags OR MF_CHECKED
   FUNCTION = CheckMenuItem(hMenu, uItem, dwFlags)
' Unchecks a menu item.
PRIVATE FUNCTION AfxUnCheckMenuItem (BYVAL hMenu AS HMENU, BYVAL uItem AS DWORD, BYVAL fByPosition AS LONG = FALSE) AS DWORD
   dwFlags = dwFlags OR MF_UNCHECKED
' Toggles the checked state of a menu item.
PRIVATE FUNCTION ToggleMenuItem (BYVAL hMenu AS HMENU, BYVAL uItem AS DWORD, BYVAL fByPosition AS LONG = FALSE) AS DWORD
   IF GetMenuState(hMenu, uItem, dwFlags) AND MF_CHECKED = MF_CHECKED THEN
' Returns TRUE if the specified menu item is checked; FALSE otherwise.
PRIVATE FUNCTION AfxIsMenuItemChecked (BYVAL hMenu AS HMENU, BYVAL uItem AS DWORD, BYVAL fByPosition AS LONG = FALSE) AS BOOLEAN
   IF GetMenuState(hMenu, uItem, dwFlags) AND MF_CHECKED = MF_CHECKED THEN FUNCTION = TRUE
' Returns TRUE if the specified menu item is enabled; FALSE otherwise.
PRIVATE FUNCTION AfxIsMenuItemEnabled (BYVAL hMenu AS HMENU, BYVAL uItem AS DWORD, BYVAL fByPosition AS LONG = FALSE) AS BOOLEAN
   DIM dwRes AS DWORD = GetMenuState(hMenu, uItem, dwFlags)
   IF ((dwRes AND MF_DISABLED) <> MF_DISABLED) AND ((dwRes AND MF_GRAYED) <> MF_GRAYED) THEN FUNCTION = TRUE
' Returns TRUE if the specified menu item is disabled; FALSE otherwise.
PRIVATE FUNCTION AfxIsMenuItemDisabled (BYVAL hMenu AS HMENU, BYVAL uItem AS DWORD, BYVAL fByPosition AS LONG = FALSE) AS BOOLEAN
   IF ((dwRes AND MF_DISABLED) = MF_DISABLED) THEN FUNCTION = TRUE
' Returns TRUE if the specified menu item is grayed; FALSE otherwise.
PRIVATE FUNCTION AfxIsMenuItemGrayed (BYVAL hMenu AS HMENU, BYVAL uItem AS DWORD, BYVAL fByPosition AS LONG = FALSE) AS BOOLEAN
   IF ((dwRes AND MF_GRAYED) = MF_GRAYED) THEN FUNCTION = TRUE
' Returns TRUE if the specified menu item is highlighted; FALSE otherwise.
PRIVATE FUNCTION AfxIsMenuItemHighlighted (BYVAL hMenu AS HMENU, BYVAL uItem AS DWORD, BYVAL fByPosition AS LONG = FALSE) AS BOOLEAN
   IF ((dwRes AND MF_HILITE) = MF_HILITE) THEN FUNCTION = TRUE
' Returns TRUE if the specified menu item is a separator; FALSE otherwise.
PRIVATE FUNCTION AfxIsMenuItemSeparator (BYVAL hMenu AS HMENU, BYVAL uItem AS DWORD, BYVAL fByPosition AS LONG = FALSE) AS BOOLEAN
   IF ((dwRes AND MF_SEPARATOR) = MF_SEPARATOR) THEN FUNCTION = TRUE
' Returns TRUE if the specified menu item is a submenu; FALSE otherwise.
PRIVATE FUNCTION AfxIsMenuItemPopup (BYVAL hMenu AS HMENU, BYVAL uItem AS DWORD, BYVAL fByPosition AS LONG = FALSE) AS BOOLEAN
   IF ((dwRes AND MF_POPUP) = MF_POPUP) THEN FUNCTION = TRUE
' Returns TRUE if the specified menu item is ownerdraw; FALSE otherwise.
PRIVATE FUNCTION AfxIsMenuItemOwnerDraw (BYVAL hMenu AS HMENU, BYVAL uItem AS DWORD, BYVAL fByPosition AS LONG = FALSE) AS BOOLEAN
   IF ((dwRes AND MF_OWNERDRAW) = MF_OWNERDRAW) THEN FUNCTION = TRUE
