Pages: [1] 2
Author Topic: WinFBE Suite 1.9.5 (November 1, 2019)  (Read 1312 times)
« on: November 01, 2019, 03:35:22 PM »
Version 1.9.5 (November 1, 2019)
- Added: ListView control.
- Added: Visual designer projects create WinFBE_VD_MAIN.bas that contains EQUATES to activate all controls that are present in the project. Thi helps reduce EXE size.
- Added: ListBox Insert method.
- Changed: Remove the Visual Designer sample project (a new one will be added in the future).
- Fixed: WinFBE project files for the those found in the "Sample_Projects" folder.
« Last Edit: November 01, 2019, 10:12:14 PM by Paul Squires »
Re: WinFBE Suite 1.9.5 (November 1, 2019)
« Reply #1 on: November 01, 2019, 09:51:59 PM »
Thanks, Paul!
Early observations, ListView Events:
ListView control added to form - all events selected except ALLEVENTS , one error only: "error 18: Element not defined, OnTextChanged"
The ListView control is visible but no mods appear to be functioning; can't add anything to control, but still testing...
« Reply #2 on: November 02, 2019, 09:26:03 AM »
Thanks Clive! You are correct - the OnTextChanged should nt be there. I have now removed it and will have the fix in the next upload.
To add to the control you can use code lie the following:
Function frmMain_Initialize( ByRef sender As wfxForm, ByRef e As EventArgs ) As LRESULT
   dim i as Long
   i = frmMain.ListView1.Columns.Add( "Column 1", 100, TextAlignment.Left )
   i = frmMain.ListView1.Columns.Add( "Column 2", 100, TextAlignment.Center )
   i = frmMain.ListView1.Columns.Add( "Column 3", 100, TextAlignment.Right )
   for ii as long = 0 to 99
      i = frmMain.ListView1.Items.Add( "Line " & ii )
      frmMain.ListView1.Item(i).SubItems.Add( "L" & ii & "Sub1" )
      frmMain.ListView1.Item(i).SubItems.Add( "L" & ii & "Sub2" )
   next
   frmMain.ListView1.Item(0).SubItem(0).ForeColor = colors.Red
   frmMain.ListView1.Item(0).SubItem(2).ForeColor = colors.Red
   frmMain.ListView1.Item(2).ForeColor = colors.Blue
   frmMain.ListView1.Item(2).BackColor = colors.Yellow
   frmMain.ListView1.Item(2).SubItem(1).ForeColor = colors.Blue
   frmMain.ListView1.SelectedIndex = 0
   Function = 0
« Reply #3 on: November 02, 2019, 11:07:17 AM »
....looks like the ListView events are not firing. I am investigating.
(EDIT: This is now fixed. Stupid omission on my part).
« Last Edit: November 02, 2019, 11:17:08 AM by Paul Squires »
« Reply #4 on: November 02, 2019, 12:35:45 PM »
Here is how to respond to a mouse double click and determine the item and/or subitem.
Function frmMain_ListView1_MouseDoubleClick( ByRef sender As wfxListView, ByRef e As EventArgs ) As LRESULT
   ? "mouse doubleclick"
   dim as POINT pt
   pt.x = e.x
   pt.y = e.y
   ScreenToClient( sender.hWindow, @pt )
   dim hitinfo as LVHITTESTINFO
   hitinfo.pt = pt
   if ListView_SubItemHitTest( sender.hWindow, @hitinfo ) <> -1 then
      ? "Item = "; hitinfo.iItem
      ? "SubItem = "; hitinfo.iSubItem
   Function = 0
« Reply #5 on: November 02, 2019, 01:36:22 PM »
Hi Paul, Yesterday I had the initialization code for the ListView in a module that was calling it too early. Moving the code to frmMain_Initialize as you recommended, got it working, thanks. The Col header responds to mouse move and mouse click.
« Last Edit: November 02, 2019, 02:02:59 PM by SeaVipe »
« Reply #6 on: November 02, 2019, 02:12:57 PM »
I have added a HitTest method for the ListView so that you can more easily check which Item and/or SubItem is clicked/Doubleclicked on.
   dim as long iItem, iSubItem
   if sender.HitTest( iItem, iSubItem ) <> -1 then
      ? "iItem = "; iItem, "iSubItem = "; iSubItem
   else
      ? "No ListView hit"
   Function = 0
« Reply #7 on: November 02, 2019, 02:19:13 PM »
I will upload a new package so that you can properly try the ListView control.
Thanks!
« Reply #8 on: November 02, 2019, 02:21:08 PM »
Great, thanks.
mjanecki
  • Little Newbie
« Reply #9 on: November 02, 2019, 02:58:10 PM »
 :(Paul
I get error messages (error 1) when I try to compile the first Project Sample pc piano. I am planning to go back to version 194 and check that one
Mark Janecki
« Reply #10 on: November 02, 2019, 06:38:01 PM »
:(Paul
Mark Janecki
Can anyone else duplicate Mark's problem? I don't get any errors.
« Reply #11 on: November 03, 2019, 07:06:34 PM »
Hi, i'm aa bit late to this party, but I've downloaded/installed, the 1.9.7 version from Paul's git hub, and none of the included examples work, piano included. I get various messages in compile, sometimes the only file loaded is the .fbe, and I am often getting Chinese type  characters. My previous software that I have written seems to be OK. Only on 32bit at the moment. Is there an example/tutorial on the listview control?
edit to add
here's a compiler error message (64bit attempt)
Failed Compile (Errors 2  Warnings 0  [2019-11-04 12:00:57])
Command Line:
C:\Users\Ray\fbetest\WinFBE_Suite\FreeBASIC-1.07.1-gcc-5.2\fbc32.exe -m "C:\Users\Ray\fbetest\WinFBE_Suite\Sample_Projects\FBPiano\FBPiano.bas" "" -v -s console
਍倀爀漀樀攀挀琀伀琀栀攀爀㘀㐀㴀ഀഀ -x C:\Users\Ray\fbetest\WinFBE_Suite\Sample_Projects\FBPiano\FBPiano.exe
error 81: Invalid command-line option, "
in case not understood, it seems that the example codes are broken, not stuff I've written myself and previously saved.
« Last Edit: November 04, 2019, 08:05:09 AM by raymw »
Joerg Buckel
  • FF3 and WinFBE+WinFBX User
« Reply #12 on: November 04, 2019, 06:28:00 AM »
Hello Paul
I don't get any errors or hints while compiling.
Greeting from Germany
Joerg
« Reply #13 on: November 04, 2019, 10:55:08 AM »
Good morning, Paul, no errors compiling FBPiano - WinFBE 1.9.7 Win32 Console (Release), Win64 Console (Release). I'll try with WinFBE 1.9.5 later.
All I have to do now is learn how to play the piano!
« Reply #14 on: November 04, 2019, 11:31:38 AM »
:(Paul
Mark Janecki
Looks like this is related to an error that fxm reported many versions ago
https://www.freebasic.net/forum/viewtopic.php?f=8&p=265796#p265744
I thought that it was fixed:
Version 1.4.8 (August 25, 2017)
- Fixed: Compiling failed in situations where spaces in file path to compiler (CreateProcess and/or FBC assembling would fail).
I will check again because maybe it is a different compile process that is failing (eg. if *.bas modules exist then they get compiled separately as part of the compile process). I will report back with a fix.
Pages: [1] 2
