Author Topic: WinFBE 1.9.8 - Find And Replace  (Read 1107 times)
« on: November 14, 2019, 05:14:47 PM »
I'm in the middle of converting a large FireFly project to WinWBE for testing. In the attached screenshot you can see I was attempting to comment out FF_ by finding and replacing FF_ with ''''FF_. I selected 'Replace All' but only the first FF_ was replaced. WinFBE inserted multiple groups of four apostrophes (single quotes) in front of the first FF_ (which took some minutes on my machine). This action is repeatable when 3 or more apostrophes are included in the replacement text (leading and trailing spaces included ' ''' ').
Find and Replace works properly on a single occurrence of FF_ with the multiple apostrophe as the replacement text (find next and replace will work all the way through the document)
Re: WinFBE 1.9.8 - Find And Replace
« Reply #1 on: November 14, 2019, 06:31:08 PM »
Hi Clive,
It's a problem with any replace, where you insert characters before the letters you are replacing, afaik. I found similar when I converted my c# program., mentioned it somewhere here. I think the process is, it finds the first occurrence of ff in your example, then replaces it with ''''ff, then the character count is such that it finds ff again, and repeats the replace and so on. You could work round it by replacing ff with ''''xx say, then replace the xx with ff  - it won't find the ff in the replacement (chose something other than xx if you may have that as actual characters). hth
edit - it was here https://www.planetsquires.com/protect/forum/index.php?topic=4329.0 first post
« Last Edit: November 14, 2019, 06:37:40 PM by raymw »
« Reply #2 on: November 14, 2019, 06:40:18 PM »
Thanks, Ray, though it's odd that Replace only exhibits that behaviour not with 1 or 2 but 3 ''' or more. You'd think after the first replacement Find would not search its own replacement string... I eventually replaced all FF_ with ' FIX -> FF_
« Reply #3 on: November 16, 2019, 11:17:48 AM »
Thanks guys.... I am testing this and will fix once I figure out the problem with the underlying find/replace algorithm.
« Reply #4 on: November 16, 2019, 11:37:22 AM »
Okay, that was easier to fix than I thought.
I was incrementing the starting position by the length of the Find phrase rather than the length of the Replace phrase.
         startPos = r + len(txtReplace)  'len(txtFind)
         ' Adjust the searching positions
         SciExec( hEdit, SCI_SETTARGETSTART, startPos, 0)
         SciExec( hEdit, SCI_SETTARGETEND, endPos, 0)
