WinFBE v3.0.0 (May 24, 2022)
Started by Paul Squires, May 24, 2022, 08:17:53 AM
WinFBE FreeBASIC Editor for Windows
WinFBE Suite includes integrated editor/compiler/tool suite. It contains the latest WinFBE, latest FBC compiler and support files, latest WinFBX (Jose's Afx includes), User Tools, and Help files. Everything is pre-configured so you should be able to simply download the archive (WinFBE_Suite.zip), unzip it, and start either the 32 or 64 bit version of the editor, compile, and success. A separate Windows Installer (winfbe_suite_setup.exe) package also exists if you prefer to use an installer rather than simply unzipping the archive. In both cases, it is recommended that you install into a folder whose name does not contain spaces because sometimes embedded folder spaces can cause compilations to fail.
Full source code and binaries are available at: https://github.com/PaulSquires/WinFBE
Release versions are available at: https://github.com/PaulSquires/WinFBE/releases
Code is written using the FreeBASIC language and uses the Scintilla editing library (in DLL form).
Features:
- Unicode enabled.
- 32 bit and 64 bit versions.
- High DPI aware for any monitor resolution.
- Language localization. Simple create language file based on English.lang file.
- Localized for many languages.
- Projects and non-project based editing.
- Easy integration of Console or GUI based code.
- Incremental compiling of code defined as a "module".
- Easy including of Windows Resource files simply by specifying which source code file is the resource.
- Seamless integration of the FreeBasic Compiler (both 32 bit and 64 bit).
- Codetip popups and auto completion.
- Built in Visual Designer.
Requirements:
- Windows Vista or later operating system. Windows XP is not supported because many newer API's are used in the source code.
Resources:
- Jose Roca: WinFBX library. Get it from https://github.com/JoseRoca/WinFBX
- Visit http://www.planetsquires.com/protect/forum/index.php for support forum.
The WinFBE editor is licensed under the GNU GPLv3 or later.
James Klutho
Thanks for the update Paul.  Looks good.  I will give it a whirl.  Is there any way to view the toolbar as was available earlier versions?
Thanks, Paul!
I downloaded the zip file, renamed my existing WinFBE_Suite to WinFBE_suite.3-Beta-3 and unzipped v3.0.0 to C:\WinFBE_Suite. Then copied (from WinFBE_suite.3-Beta-3) WinFBE.ini and user_snippets.ini to the new Settings folder and dark.theme to the new themes folder - works great and my theme settings and projects list and snippets are all correct...
philbar
Hi Paul.
First of all, thanks for the shiny new update. WinFBE/WinFBX has been and remains my favorite way to make Windows programs.
Second, here are two things that I really, really should have noticed when you were doing betas. I don't know where my attention was.
A) If I start a designer project, add one or more forms and then use Save All to save them, the Form.inc files don't show up in the Explorer. Doesn't happen if I save them individually. If I close WinFBE and re-open the project, they still aren't in the Explorer. See the picture.
B) If I modify one form, then modify the other form, then switch back and forth between forms, the unsaved indicators on the tabs go away.
Hi Paul, The Designer Menu is mostly greyed.
Also...
Old issue with Designer not able to scroll to the bottom of Forms higher than 885 pixels.
I have found that scrolling to the bottom of a form higher than 885 pixels and then manually setting the height to < 885 pixels and then grabbing the now visible resize grabber and dragging it down to 885 pixels (where it stops increasing the height) will display the bottom of the form and the StatusBar (which so far has not been visible). Perhaps there is a limit to the height of a form? My monitors can display forms higher than 885 pixels.
For when you start working on the Designer!
I love the feel of this, and everything looks bright and "crisp" (due to a lack of a better word)
I just want to start something new right away.
While we are not having the Auto-resize of controls yet, i was hoping to learn how that worked and perhaps do it manually.
From my understanding you have a list of the controls, their locations and the original form size.
Then on the WM_size you retake the from size and move the controls again in relation to those new parameters.
I get the feeling its not going to be as easy as it sounds.... ;-)
Regards,
Peter
-Regards
Peter
Quote from: James Klutho on May 24, 2022, 05:34:09 PM
Hi James, sorry but the Toolbar is gone, never to be seen again in the same vein that editors like Visual Studio Code has done away with them. WinFBE now has extensive keyboard shortcut support as well as you being able to click on the various panels in the statusbar that will pop up the related function.
Quote from: philbar on May 25, 2022, 12:05:26 PM
You are correct and I have been able to re-create this problem with the "Save All" on new Forms. I will fix it.
I have not been able to duplicate this behaviour yet. I'll keep looking.
Quote from: SeaVipe on May 25, 2022, 10:40:25 PM
Thanks Clive, yes that does seem to be a problem that I will fix.
Quote from: SeaVipe on May 25, 2022, 10:51:03 PM
Thanks! Yes, this has been a long standing problem with the visual designer that I really to fix... finally.  :-)
Quote from: Petrus Vorster on May 26, 2022, 06:46:32 AM
Thanks Peter :-)
Your approach to resizing controls is correct. It is not that difficult but it can be cumbersome especially if you have a lot of controls that need to be resized and/or repositioned. If you run into trouble then be sure to post. Sometimes people get confused when positioning controls and getting the relative window based coordinates confused with the screen coordinates (and then also being able to convert back and forth between the two). I also create one function for each Form that houses all of the resize code and I call that code from the Form's main load event and also the Form's Size event. This prevents code duplication.
philbar
@Petrus Vorster:
Forgive me for butting in, but for resizing you might want to look at the Clayout control in WinFBX. It works very well, and I think it deserves to be advertised. Check out the layout manager programs in the templates.
In order to use it in a Designer program, you have to come at it "sideways" because everything in the examples happens in the main program, but everything in a designer form happens in an event function. Basically, you just create the layout control and attach it to your form in Form_Load. Then for each control on the form you specify that this one is anchored to the left edge and it scales only by width, that one is anchored to the top and it scales by width and height, etc. Then in the Form_Resize event, you just call the AdjustControls member of the layout control. When the form closes, you delete the layout control.
If anyone is interested, I can post a sample Designer program that uses Clayout to auto-resize.
-Regards
Peter
I recon I will post a lot of questions soon.
The WFXTextbox control has a bunch of neat features.
But I don't see a MaxLEN setting.
That is something I use extensively , especially in the SMS platform I made for work.
Would you need to add code to each of those controls Keydown events or am i just overlooking the obvious?
Regards,
Peter
-Regards
Peter
