I have adapted another old control by Börje to FreeBasic, making it DPI and Unicode aware.
Demonstrates how to make a custom control subclassing an existing one.
' Microsoft Windows
' File: CbColor.inc
' Contents: Combobox color list
' Based on the CBCOLOR control originally written by Börje Hagsten in 2001.
' Compiler: FreeBasic 32 & 64-bit
' Freeware. Use at your own risk.
' Copyright (c) 2016 Jose Roca. All Rights Reserved.
#pragma once
#include once "Afx/CWindow.inc"
#include once "win/commdlg.bi"
USING Afx.CWindowClass
NAMESPACE Afx.CCbColorClass
CONST CBCOL_SETAUTOCOLOR = WM_USER + 100
CONST CBCOL_SETUSERCOLOR = WM_USER + 101
CONST CBCOL_SETCOLORNAME = WM_USER + 102
CONST CBCOL_GETAUTOCOLOR = WM_USER + 200
CONST CBCOL_GETUSERCOLOR = WM_USER + 201
CONST CBCOL_GETSELCOLOR = WM_USER + 202
' CCbColor class
TYPE CCbColor
Protected:
m_hCtl AS HWND ' // Button handle
m_hFont AS HFONT ' // Font handle
m_oldProc AS WNDPROC ' // Subclass procedure
Public:
m_autoColor AS COLORREF ' // Auto color
m_userColor AS COLORREF ' // User color
m_ratio AS SINGLE ' // DPI ratio - width
DIM m_rgColors(15) AS COLORREF
DIM m_rgNames (17) AS WSTRING * 20 = {"Auto", "Black", "Blue", "Green", "Cyan", "Red", _
"Magenta", "Brown", "Light Gray", "Gray", "Light Blue", "Light Green", "Light Cyan", _
"Light Red", "Light Magenta", "Yellow", "Bright White", "User selected..."}
DECLARE CONSTRUCTOR (BYVAL pWindow AS CWindow PTR, BYVAL cID AS INTEGER, _
BYVAL x AS LONG = 0, BYVAL y AS LONG = 0, BYVAL nWidth AS LONG = 0, BYVAL nHeight AS LONG = 0, _
BYVAL dwAutoColor AS COLORREF = 0, BYVAL dwUserColor AS COLORREF = 0)
DECLARE DESTRUCTOR
DECLARE FUNCTION hWindow () AS HWND
DECLARE FUNCTION GetQBColor (BYVAL hWnd AS HWND, BYVAL c AS LONG, BYVAL dlg AS LONG) AS COLORREF
DECLARE PROPERTY AutoColor (BYVAL nColor AS COLORREF)
DECLARE PROPERTY AutoColor () AS COLORREF
DECLARE PROPERTY UserColor (BYVAL nColor AS COLORREF)
DECLARE PROPERTY UserColor () AS COLORREF
DECLARE PROPERTY SelColor () AS COLORREF
END TYPE
' Window procedure
FUNCTION CCbColorProc (BYVAL hwnd AS HWND, BYVAL uMsg AS UINT, BYVAL wParam AS WPARAM, BYVAL lParam AS LPARAM) AS LRESULT
DIM pCbColor AS CCbColor PTR
SELECT CASE uMsg
CASE WM_CREATE
CASE WM_DESTROY
' // Remove the subclassing
SetWindowLongPtrW hwnd, GWLP_WNDPROC, CAST(LONG_PTR, RemovePropW(hwnd, "OLDWNDPROC"))
' // Remove the property
.RemovePropW(hwnd, "CBCOLORPTR")
CASE WM_DRAWITEM
' // Get a pointer to the class
pCbColor = CAST(CCbColor PTR, .GetPropW(hwnd, "CBCOLORPTR"))
IF pCbColor = NULL THEN EXIT FUNCTION
SCOPE
DIM hBrush AS HBRUSH, wszText AS WSTRING * 80
DIM lpdis AS DRAWITEMSTRUCT PTR, rc AS RECT
lpdis = CAST(DRAWITEMSTRUCT PTR, lParam)
IF lpdis->itemID = &hFFFFFFFF THEN EXIT FUNCTION
SELECT CASE lpdis->itemAction
CASE ODA_DRAWENTIRE, ODA_SELECT
' // Clear background
FillRect lpdis->hDC, @lpdis->rcItem, .GetSysColorBrush(COLOR_WINDOW)
' // Get/draw text
.SendMessageW hwnd, CB_GETLBTEXT, lpdis->itemID, CAST(.LPARAM, @wszText)
.SetBkColor lpdis->hDC, GetSysColor(COLOR_WINDOW)
.SetTextColor lpdis->hDC, GetSysColor(COLOR_WINDOWTEXT)
rc = lpdis->rcItem
rc.Left = 28 * (pCbColor->m_ratio * 0.72)
.DrawTextW lpdis->hDC, @wszText, LEN(wszText), @rc, DT_SINGLELINE OR DT_LEFT OR DT_VCENTER
' // If selected item...
IF (lpdis->itemState AND ODS_SELECTED) THEN
' // If not ODS_COMBOBOXEDIT...
IF (lpdis->itemState AND ODS_COMBOBOXEDIT) = 0 THEN
' // Set coordinates
rc.Left = 26 * (pCbColor->m_ratio * 0.72)
rc.Right = lpdis->rcItem.Right
rc.Top = lpdis->rcItem.Top
rc.Bottom = lpdis->rcItem.Bottom
' // Invert area around text only
.InvertRect lpdis->hDC, @rc
' // and draw a focus rectangle around all
.DrawFocusRect lpdis->hDC, @lpdis->rcItem
' // Paint color rectangle using RoundRect for nicer looks
' /// If ODS_COMBOBOXEDIT...
IF (lpdis->itemState AND ODS_COMBOBOXEDIT) THEN
rc.Left = 4 * (pCbColor->m_ratio * 0.72)
rc.Right = 24 * (pCbColor->m_ratio * 0.72)
' // A tiny bit to the left in list...
rc.Left = 3 * (pCbColor->m_ratio * 0.72)
rc.Right = 23 * (pCbColor->m_ratio * 0.72)
rc.Top = (lpdis->rcItem.Top + (2 * pCbColor->m_ratio))
rc.Bottom = (lpdis->rcItem.Bottom - (2 * pCbColor->m_ratio))
' // Create brush with the appropriate color
hBrush = .CreateSolidBrush(pCbColor->GetQBColor(hWnd, lpdis->itemID, FALSE))
' // Select brush into device context
hBrush = .SelectObject(lpdis->hDC, hBrush)
' // Draw the rectangle
DIM nCorner AS LONG = pCbColor->m_ratio * 0.72
.RoundRect(lpdis->hDC, rc.Left, rc.Top, rc.Right, rc.Bottom, nCorner, nCorner)
' // Select old brush back and delete new one
.DeleteObject .SelectObject(lpdis->hDC, hBrush)
END SCOPE
FUNCTION = CTRUE
' // Set auto color
CASE CBCOL_SETAUTOCOLOR
pCbColor->m_AutoColor = wParam
' // Set auto color
CASE CBCOL_GETAUTOCOLOR
FUNCTION = pCbColor->m_AutoColor
' // Set user color
CASE CBCOL_SETUSERCOLOR
FUNCTION = pCbColor->m_UserColor
' // Get user color
CASE CBCOL_GETUSERCOLOR
' // Return selected color
CASE CBCOL_GETSELCOLOR
DIM nRes AS LONG
nRes = SendMessageW(hwnd, CB_GETCURSEL, 0, 0)
IF nRes > CB_ERR THEN
FUNCTION = pCbColor->GetQBColor(hwnd, nRes, CTRUE)
' // Default processing for other messages.
FUNCTION = CallWindowProcW(GetPropW(hwnd, "OLDWNDPROC"), hwnd, uMsg, wParam, lParam)
' CPgBar3D class constructor
CONSTRUCTOR CCbColor (BYVAL pWindow AS CWindow PTR, BYVAL cID AS INTEGER, _
' // Create the control
IF pWindow THEN
m_hCtl = pWindow->AddControl("COMBOBOX", pWindow->hWindow, cID, "", _
x, y, nWidth, nHeight, WS_CHILD OR WS_VISIBLE OR CBS_OWNERDRAWFIXED OR CBS_HASSTRINGS OR _
CBS_DROPDOWNLIST OR WS_TABSTOP OR CBS_DISABLENOSCROLL OR WS_VSCROLL, WS_EX_CLIENTEDGE, _
NULL, CAST(WNDPROC, @CCbColorProc))
m_ratio = pWindow->rxRatio
IF m_hCtl THEN
' // Set the same font used by the parent
DIM lfw AS LOGFONTW
IF pWindow->Font THEN
IF GetObjectW(pWindow->Font, SIZEOF(lfw), @lfw) THEN m_hFont = CreateFontIndirect(@lfw)
' // Store a pointer to the class as a property
.SetPropW(m_hCtl, "CBCOLORPTR", CAST(HANDLE, @this))
DIM i AS LONG
FOR i = 0 TO UBOUND(m_rgNames)
SendMessageW m_hCtl, CB_ADDSTRING, 0, CAST(LPARAM, @m_rgNames(i))
' // Store default values (usually COLOR_WINDOW or COLOR_WINDOWTEXT)
m_AutoColor = dwAutoColor
m_UserColor = dwUserColor
' // Create initial colormap for the ChooseColor dialog
DIM cl AS LONG
FOR i = 1 TO 16
cl = i * 16 - 1
m_rgColors(16 - i) = BGR(cl, cl, cl)
END CONSTRUCTOR
' CPgBar3D class destructor
DESTRUCTOR CCbColor
' // Free resources
IF m_hFont THEN DeleteObject m_hFont
END DESTRUCTOR
' Returns the handle of the button
FUNCTION CCbColor.hWindow () AS HWND
FUNCTION = m_hCtl
' Basic QB color function.
FUNCTION CCbColor.GetQBColor (BYVAL hwnd AS HWND, BYVAL c AS LONG, BYVAL dlg AS LONG) AS COLORREF
SELECT CASE c
CASE 0 : FUNCTION = m_AutoColor ' // Pre-set system color, like COLOR_WINDOW or COLOR_WINDOWTEXT
CASE 1 : FUNCTION = BGR(0, 0, 0) ' // Black
CASE 2 : FUNCTION = BGR(0, 0, 128) ' // Blue
CASE 3 : FUNCTION = BGR(0, 128, 0) ' // Green
CASE 4 : FUNCTION = BGR(0, 128, 128) ' // Cyan
CASE 5 : FUNCTION = BGR(196, 0, 0) ' // Red
CASE 6 : FUNCTION = BGR(128, 0, 128) ' // Magenta
CASE 7 : FUNCTION = BGR(128, 64, 0) ' // Brown
CASE 8 : FUNCTION = BGR(196, 196, 196) ' // Light Gray
CASE 9 : FUNCTION = BGR(128, 128, 128) ' // Gray
CASE 10 : FUNCTION = BGR(0, 0, 255) ' // Light Blue
CASE 11 : FUNCTION = BGR(0, 255, 0) ' // Light Green
CASE 12 : FUNCTION = BGR(0, 255, 255) ' // Light Cyan
CASE 13 : FUNCTION = BGR(255, 0, 0) ' // Light Red
CASE 14 : FUNCTION = BGR(255, 0, 255) ' // Light Magenta
CASE 15 : FUNCTION = BGR(255, 255, 0) ' // Yellow
CASE 16 : FUNCTION = BGR(255, 255, 255) ' // White
CASE 17
' // Display the ChooseColor dialog
IF dlg THEN
DIM cc AS CHOOSECOLORW
' // Size of the structure
cc.lStructSize = SIZEOF(cc)
' // Pointer to the custom defined gray color array
cc.lpCustColors = @m_rgColors(0)
cc.Flags = CC_RGBINIT OR CC_FULLOPEN
cc.hwndowner = hwnd
' // Allow the dialog to "auto-select" previously selected color
' // (only works for base colors, but still better than nothing)
cc.rgbResult = m_UserColor
IF .ChooseColorW(@cc) THEN
m_UserColor = cc.rgbResult
.InvalidateRect hwnd, NULL, 0
.UpdateWindow hWnd
' // Return the user selected color
FUNCTION = m_UserColor
' Gets/sets the RGB auto color
PROPERTY CCbColor.AutoColor (BYVAL nColor AS COLORREF)
m_autoColor = nColor
END PROPERTY
PROPERTY CCbColor.AutoColor () AS COLORREF
PROPERTY = m_autoColor
END PROPERTY
' Gets/sets the RGB user color
PROPERTY CCbColor.UserColor (BYVAL nColor AS COLORREF)
END PROPERTY
PROPERTY CCbColor.UserColor () AS COLORREF
END PROPERTY
' Get the selected color
PROPERTY CCbColor.SelColor () AS COLORREF
DIM nSel AS LRESULT
nSel = SendMessageW(m_hCtl, CB_GETCURSEL, 0, 0)
IF nSel > CB_ERR THEN PROPERTY = this.GetQBColor(m_hCtl, nSel, 1)
END PROPERTY
END NAMESPACE
