Author Topic: WinFBE v3.0.0-BETA-3 (April 17, 2022)  (Read 325 times)
« on: April 17, 2022, 09:55:55 PM »
Hi everyone,
Thank-you for all of the valuable feedback on the first and second beta.
Here is the download link for the third beta for WinFBE Version 3.
https://github.com/PaulSquires/WinFBE/releases/download/2.2.0/WinFBE_Suite3-BETA-3.zip
DO NOT USE THIS ON YOUR PRODUCTION CODE UNLESS YOU HAVE FULLY BACKED UP YOUR PROJECTS. I SAY THIS BECAUSE I WOULD HATE FOR ANYTHING IN YOUR PROJECTS TO BE COMPROMISED BY THIS BETA
KNOWN ISSUES RELATED BETA-3
- The vertical scrollbar thumbs will shrink very small when huge number of lines exist in a document. Need to add logic that resizes the thumbs to a minimum size and then correctly calculate the lines to display in the editor when the thumb is moved.
- The "Check for Updates" feature has been disabled for the Beta releases.
CHANGES FOR BETA 3
Version 3.0.0-BETA-3
Editor:
- Fixed regression whereby Backspace key was non-functional in editing textboxes in the Visual Designer Property List.
- Fixed setting IndentGuides editor theme colors.
- Fixed SetCompilerPathsII user tool being generated for new default winfbe configuration files.
- Removed Identifiers theme colors from the *.theme files because they overrode editor.text values.
- Fixed GPF due to invalid array access when positioning an editor tab in the top tab control.
- Fixed "Convert to Mixed Case" keyboad shortcut from Ctrl+Alt+M to Ctrl+Alt+X.
Re: WinFBE v3.0.0-BETA-3 (April 17, 2022)
« Reply #1 on: April 18, 2022, 04:32:49 PM »
Hi Paul, I haven't been able to break Beta-3 yet!
Will CTRL + arrow keys and SHIFT + arrow keys be enabled in the Designer for the release version of WinFBE 3?
« Reply #2 on: April 18, 2022, 08:20:05 PM »
hmmmm... it does look like that functionality is no longer functional!  :-)  I will fix that. If you see anything else in the Visual Designer that does not work like it used to then please let me know.
Paul
« Reply #3 on: April 19, 2022, 09:54:18 AM »
Thanks Clive, this problem is now fixed. Thanks for reporting this one. I have not done a lot of work related to the visual designer for the new Version 3, because I focused almost solely on the editor itself for this update.
jermy
« Reply #4 on: April 19, 2022, 04:24:54 PM »
Hi paul,
Missing Ctrl+b and ctrl+shift+b for commenting and uncommenting multiple lines.
« Reply #5 on: April 19, 2022, 06:35:35 PM »
Hi jermy, those keyboard shortcuts were changed to Ctrl+/ and Ctrl+Shift+/ to be consistent with other editors. However, you can easily re-add the older keyboard shortcuts by setting in the "Keyboard Shortcuts" dialog (Ctrl+K).
Bruce Huber
« Reply #6 on: April 22, 2022, 07:25:36 PM »
Paul, on x64, when typing into the find/replace text fields, it is often losing focus and further typing just goes into the bit-bucket somewhere.
CBruce
EDIT: Moved to its own post:
https://www.planetsquires.com/protect/forum/index.php?topic=4600.0
« Last Edit: April 22, 2022, 10:28:24 PM by Bruce Huber »
